Perfect Failure Detection with Very Few Bits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
A failure detector is a distributed oracle that provides each process with a module that continuously outputs an estimate of which processes in the system have failed. The perfect failure detector provides accurate and eventually complete information about process failures. We show that, in asynchronous failure-prone message-passing systems, perfect failure detection can be achieved by an oracle that outputs at most ⌈log α(n)⌉ + 1 bits per process in n-process systems, where α denotes the inverse-Ackermann function. This result is essentially optimal, as we also show that, in the same environment, no failure detector outputting a constant number of bits per process can achieve perfect failure detection.
fdenc-longversion.pdf (339.87 Ko) Télécharger le fichier
hal-01365304 , version 1 (13-09-2016)
  • HAL Id : hal-01365304 , version 1
Pierre Fraigniaud, Sergio Rajsbaum, Corentin Travers, Petr Kuznetsov, Thibault Rieutord. Perfect Failure Detection with Very Few Bits. [Research Report] LaBRI - Laboratoire Bordelais de Recherche en Informatique. 2016. ⟨hal-01365304⟩
164 Consultations
239 Téléchargements
