Decentralized Approximation Algorithm for Data Placement Problem in Content Delivery Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent advancements in Internet technology research, as well as the widespread of commercial content delivery networks, motivates the need for optimization algorithms designed to work in decentralized manner. In this paper we formulate data placement problem, a special case of universal facility location problem with quadratic terms in objective function. The considered combinatorial optimization problem is NP-hard. A randomized algorithm is presented that approximates the solution within factor O(log n) in decentralized environment, assuming asynchronous message passing of bounded sizes.
978-3-642-28255-3_10_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01365572 , version 1 (13-09-2016)
Paternité
Maciej Drwal, Jerzy Józefczyk. Decentralized Approximation Algorithm for Data Placement Problem in Content Delivery Networks. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.85-92, ⟨10.1007/978-3-642-28255-3_10⟩. ⟨hal-01365572⟩
35 Consultations
52 Téléchargements
