Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : The evolution of tool-machines shows a trend for integration of different machining functionalities such as, milling, turning, and drilling, on a same machine. These machines are result of the mechatronics development that allows the aggregation of different functionalities into a unique machine (named multifunctional machine tool - MMT). However from the point of view of the production process there is a limitation of the conventional process control solution, i.e., when the systems are composed by MMTs, their functional flexibilities are considered only during scheduling and encapsulated at this level, and during the process execution, MMTs are viewed as traditional ones. Then, the multi-functionalities are not explored for resources allocation. Thus, a new process control approach is proposed here to dynamically allocate the resources exploring the functional flexibilities of MMTs.
https://hal.inria.fr/hal-01365578 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Tuesday, September 13, 2016 - 3:21:33 PM Last modification on : Tuesday, September 13, 2016 - 5:06:05 PM Long-term archiving on: : Wednesday, December 14, 2016 - 2:47:44 PM
Osvaldo L. Asato, Guilherme M. Dobrianskyj, Fabrício Junqueira, Diolino J. Santos Filho, Paulo E. Miyagi. Process Control System Considering the Machines Functional Flexibilities. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.133-142, ⟨10.1007/978-3-642-28255-3_15⟩. ⟨hal-01365578⟩
