Trajectory generation for two robots cooperating to perform a task, Proceedings of IEEE International Conference on Robotics and Automation, pp.1626-1631, 1996. ,
DOI : 10.1109/ROBOT.1996.506945
Path Planning and Control of a Cooperative Three-Robot System Manipulating Large Objects, Journal of Intelligent and Robotic Systems, vol.22, issue.2, pp.99-116, 1998. ,
DOI : 10.1023/A:1007943632269
Cinemática de Robôs Cooperativos, UFSC. Florianópolis-SC, 2005. ,
A multi-arm robotic system for optimal sculpting, Robotics and Computer-Integrated Manufacturing, vol.24, issue.1, pp.92-104, 2005. ,
DOI : 10.1016/j.rcim.2006.08.001
Screw-based relative Jacobian for manipulators cooperating in a task using Assur virtual chains, Proceedings of 20th International Congress of Mechanical Engineering. ABCM, 2009. ,
Trajectory Planning with redundant cooperative robotics systems, Proceedings of 20th International Congress of Mechanical Engineering. ABCM, Brazil, 2009. ,
The screw theory applied to compute the kinematics of multi-robots system in cooperative tasks, Proceedings of the 20th International Conference on Flexible Automation and Intelligent Manufacturing, 2010. ,
Simulation of Multi-robot Cooperative Systems programming based on a three environment definition, Proceedings of the 12th Mechatronics Forum Biennial International Conference. Swiss Federal Institute of Technology, 2010. ,
Don't cross-thread the screw. A Symposium Commemorating the Legacy, Works, and Life of Sir Robert Stawell Ball Upon the 100th Anniversary of A Treatise on the Theory of Screws, pp.1-56, 2000. ,
Kirchhoff's circulation law applied to multi-loop kinematic chains. Mechanism and Machine Theory, pp.171-183, 1981. ,
A comparison between the Denavit-Hartenberg and the screw-based methods used in kinematic modeling of robot manipulators Robotics and Computer-Integrated Manufacturing, Conference papers of Flexible Automation and Intelligent Manufacturing, pp.723-728, 2011. ,
Robot Analysis: The Mechanics of Serial and Parallel Manipulators, INC, 1999. ,
Differential kinematics of serial manipulators using virtual chains, Journal of the Brazilian Society of Mechanical Sciences and Engineering, vol.27, issue.4, pp.345-356, 2005. ,
DOI : 10.1590/S1678-58782005000400002
