Characteristics of Inrush Current of Present Designs of Power Transformers, 2007 IEEE Power Engineering Society General Meeting, 2007. ,
DOI : 10.1109/PES.2007.386291
An Improved Transformer Inrush Restraint Algorithm Increases Security While Maintaining Fault Response Performance, Proc. 53rd Annual Conf. for Protective Relay Engineers, 2000. ,
A Current-Based Solution for Transformer Differential Protection. Part I: Problem Statement, IEEE Power Engineering Review, vol.21, issue.8, pp.485-491, 2001. ,
DOI : 10.1109/MPER.2001.4311564
Sensitive Turn-to-Turn Fault Protection for Power Transformers, 2005. ,
An Equivalent Instantaneous Inductance-Based Technique for Discrimination Between Inrush Current and Internal Faults in Power Transformers, IEEE Transactions on Power Delivery, vol.20, issue.4, pp.2473-2482, 2005. ,
DOI : 10.1109/TPWRD.2005.855443
An EPVA-Based Strategy for Power Transformers Differential Protection, Proc. Advanced Research Workshop on Modern Transformers, 2010. ,
Power differential method for discrimination between fault and magnetizing inrush current in transformers, IEEE Transactions on Power Delivery, vol.12, issue.3, pp.1109-1118, 1997. ,
DOI : 10.1109/61.636909
Advances in Transformer Protection: A Review, Electric Power Components and Systems, vol.139, issue.11, pp.1203-1209, 2005. ,
DOI : 10.1109/61.714488
The Use of the Instantaneous-Reactive-Power Signature Analysis for Rotor-Cage-Fault Diagnostics in Three-Phase Induction Motors, IEEE Transactions on Industrial Electronics, vol.56, issue.11, pp.4606-4614, 2009. ,
DOI : 10.1109/TIE.2009.2027922
Improved Overcurrent Protection Using Symmetrical Components, IEEE Transactions on Power Delivery, vol.22, issue.2, pp.843-850, 2007. ,
DOI : 10.1109/TPWRD.2007.893591
A Permeance-Based Transformer Model and Its Application to Winding Interturn Arcing Fault Studies, IEEE Transactions on Power Delivery, vol.25, issue.3, pp.1589-1598, 2010. ,
DOI : 10.1109/TPWRD.2009.2039149
Power transformers behavior under the occurrence of inrush currents and turn-to-turn winding insulation faults, The XIX International Conference on Electrical Machines, ICEM 2010, 2010. ,
DOI : 10.1109/ICELMACH.2010.5608303
