Trends in active power line conditioners, IEEE Trans. Power Electron, vol.9, issue.3, pp.271-350, 1994. ,
Modern Active Filters and traditional passive filters. Bulletin of the Polish Academy of sciences, pp.255-269, 2006. ,
Active power line conditioner based on two parallel converters topology, IEEE Compatibility in Power Electronics, 2005., pp.134-140, 2005. ,
DOI : 10.1109/CPE.2005.1547558
Some improvements in 81-Level Inverters for Traction Applications, Proc. of 21th Electric Vehicle Sysmposium (EVS 21), 2005. ,
Hybrid solutions for improving passive filter performance in high power applications, IEEE Transactions on Industry Applications, vol.33, issue.3, pp.732-747, 1997. ,
DOI : 10.1109/28.585864
Neuro-fuzzy Control System for Active Filter with Load Adaptation. Compatibility and Power Electronics CPE2011, pp.28-31, 2011. ,
Power Quality Converters with Minimum Number of Current Sensor Requirement. International school on nonsinusoidal currents and compensation, pp.1-4, 2008. ,
Method of choice elements of active line conditioner, Journal of Chernigov, issue.40, pp.223-232, 2009. ,
