Conference papers
Solid-State Bipolar Marx Generator with Voltage Droop Compensation
Abstract : This paper addresses the voltage droop compensation associated with long pulses generated by solid-stated based high-voltage Marx topologies. In particular a novel design scheme for voltage droop compensation in solid-state based bipolar Marx generators, using low-cost circuitry design and control, is described. The compensation consists of adding one auxiliary PWM stage to the existing Marx stages, without changing the modularity and topology of the circuit, which controls the output voltage and a LC filter that smoothes the voltage droop in both the positive and negative output pulses. Simulation results are presented for 5 stages Marx circuit using 1 kV per stage, with 1 kHz repetition rate and 10% duty cycle.
Document type :
Conference papers
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01365752
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, September 13, 2016 - 3:54:03 PM
Last modification on : Friday, August 5, 2022 - 12:40:04 PM
Long-term archiving on: : Wednesday, December 14, 2016 - 2:39:04 PM
File
978-3-642-28255-3_45_Chapter.p...
Identifiers
Citation
H. Canacsinh, José Fernando Silva, Sónia F. Pinto, Luis M. Redondo. Solid-State Bipolar Marx Generator with Voltage Droop Compensation. 3rd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2012, Costa de Caparica, Portugal. pp.411-418, ⟨10.1007/978-3-642-28255-3_45⟩. ⟨hal-01365752⟩
Share
Metrics
Record views
44
Files downloads
363
