Studies on nonvolatile resistance memory switching in ZnO thin films, Bulletin of Materials Science, vol.39, issue.3, pp.247-252, 2009. ,
DOI : 10.1007/s12034-009-0037-5
Resistive switching in transition metal oxides, Materials Today, vol.11, issue.6, pp.28-36, 2008. ,
DOI : 10.1016/S1369-7021(08)70119-6
High dielectric constant oxides, The European Physical Journal Applied Physics, vol.28, issue.3, pp.265-291, 2004. ,
DOI : 10.1051/epjap:2004206
Charge trapping memory structures with Al2O3 trapping dielectric for high-temperature applications, Solid-State Electronics, vol.49, issue.5, pp.716-720, 2005. ,
DOI : 10.1016/j.sse.2004.09.003
Low???Frequency Negative Resistance in Thin Anodic Oxide Films, Journal of Applied Physics, vol.33, issue.9, pp.2669-2682, 1962. ,
DOI : 10.1063/1.1702530
Post-breakdown conduction in thin film Al???(Al2O3)???CdS???Al switching element, Thin Solid Films, vol.9, issue.3, pp.357-361, 1972. ,
DOI : 10.1016/0040-6090(72)90125-3
Trapping of electrons in metal oxide-polymer memory diodes in the initial stage of electroforming, Applied Physics Letters, vol.97, issue.22, p.222106, 2010. ,
DOI : 10.1063/1.3520517
Voltage-dependent dielectric breakdown and voltage-controlled negative resistance in anodized Al???Al2O3???Au diodes, Journal of Applied Physics, vol.88, issue.5, pp.2805-2812, 2000. ,
DOI : 10.1063/1.1287116
Oxygen vacancy levels and interfaces of Al2O3, Microelectronic Engineering, vol.86, issue.7-9, pp.1668-1671, 2009. ,
DOI : 10.1016/j.mee.2009.03.011
Oxygen and aluminum diffusion in ??-Al2O3: How much do we really understand?, Journal of the European Ceramic Society, vol.28, issue.7, pp.1495-1507, 2008. ,
DOI : 10.1016/j.jeurceramsoc.2007.12.020
layer, Nanotechnology, vol.22, issue.25, pp.254028-254032, 2011. ,
DOI : 10.1088/0957-4484/22/25/254028
URL : https://hal.archives-ouvertes.fr/hal-01132519
Electroforming, Switching and Memory Effects in Oxide Thin Films, ElectroComponent Science and Technology, vol.3, issue.4, pp.217-224, 1977. ,
DOI : 10.1155/APEC.3.217
Effects of space charge at the conjugated polymer/electrode interface, Journal of Applied Physics, vol.91, issue.8, pp.5182-5189, 2002. ,
DOI : 10.1063/1.1454188
Electron trapping properties of Ge-implanted SiO2, Microelectronic Engineering, vol.22, issue.1-4, pp.123-126, 1993. ,
DOI : 10.1016/0167-9317(93)90144-T
Determination of trapping parameters in poly(p-phenylenevinylene) light-emitting devices using thermally stimulated currents, Journal of Applied Physics, vol.84, issue.1, pp.87-92, 1998. ,
DOI : 10.1063/1.368004
