José Barata, and Sebastian Scholze Evaluation of a P300-Based Interface for Smart Home Control, p.179 ,
Alina Ninett Panfir, and Doru Talaba Part VIII: Robotic Systems Kinematics Programming for Cooperating Robotic Systems, p.189 ,
Henrique Simas, and Altamir Dias Measuring Variables Effect to Statistically Model the Multi-Robot Patrolling Problem by Means of ,
Perceptional Systems Perception of Motion and Architectural Form: Computational Relationships between Optical Flow and Perspective, p.219 ,
Lambert-Torres, and Se Un Ahn Short Time Fourier Transform and Automatic Visual Scoring for the Detection of Sleep Spindles, Adaptive Filter and Resonant Controller Applied to Hybrid Series Active Power Filter, p.267 ,
Energy Multiple Stress Life Analysis on Underground Power Cables from Distribution Networks 275 Larisa Mariut and Elena Helerea Power Transformers Differential Protection Using the p-q Power Theory, p.283 ,
Marques Cardoso Experimental Results of Parallel Active Filter Implementation in Nonideal Power Grid, 291 Oleksandr Husev, Andrei Blinov, and Dmitri Vinnikov Design of Current Power Sources for a FFC NMR Apparatus ,
Redondo Hybrid Evolutionary Neuro-fuzzy Computational Tool to Forecast Wind Power and Electricity Prices Catalão Simulation and Experimental Results for a Photovoltaic System Formed by Monocrystalline Solar Modules Catalão Experimental Analysis of a Standalone Renewable Energy Based Hybrid System, 337 Nuno Freire, Eunice Ribeiro, António J. Marques Cardoso, and Chiara Boccaletti Table of Contents XIII Part XIII: Energy Smart Grid Development of Energy Monitoring System for SmartGrid Consumer Application Leonids Ribickis, and Janis Zakis A Standard-Based Software Infrastructure to Support Power System Protection in Distributed Energy Systems, p.355 ,
Stanimir Valtchev, and Svilen Valtchev Solar Trigeneration System Model for Off-Grid Residential ,
Power Electronics Interactive Power Electronics Tool for Undergraduate Laboratories, p.387 ,
Rossi Solid-State Bipolar Marx Converter with Output Transformer and Energy Recovery, 403 H. Canacsinh, José Fernando Silva, Sónia F. Pinto, Luis M. Redondo, and João Santana Solid-State Bipolar Marx Generator with Voltage Droop Compensation 411 H. Canacsinh, José Fernando Silva, Sónia F. Pinto, and Luis M. Redondo Part XV: Electronics Design of Robust CMOS Amplifiers Combining Advanced Low-Voltage and Feedback Techniques . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 421 Somayeh Abdollahvand ,
Quintana On Implementation Possibilities of High-Voltage IGBTs in Resonant Converters, p.443 ,
Optimization in Electronics Optimization-Based Design of Nano, p.453 ,
Ventim-Neves Robust Optimization-Based High Frequency Gm-C Filter Design, p.465 ,
Telecommunications and Electronics Efficient Hybrid Continuous-Time, 485 J. Gerardo García-Sánchez and José M. de la Rosa Interference Distribution of a CDMA Cognitive Radio Ad Hoc Network, p.493 ,
Rui Dinis, and Luis Bernardo Photonics Active Filters Based on SiC Multilayer Structures: A Two Stage Active Circuit, p.503 ,
Electroforming Process in Metal-Oxide-Polymer Resistive Switching Memories, p.527 ,
URL : https://hal.archives-ouvertes.fr/hal-01365772
Meskers Dynamic Behavior of Resistive Random Access Memories (RRAMS) Based on Plastic Semiconductor, p.535 ,
Workshop on Data Analysis and Modeling Retina in Health and Disease Fovea and Optic Disc Detection in Retinal Images with Visible Lesions, p.543 ,
Coll de Tuero Mathematical Analysis and Computational Integration of Massive Heterogeneous Data from the Human Retina, Automatic Arteriovenous Ratio Computation: Emulating the Experts, p.571 ,
Assadi Automated Evaluation of Retinopathies Using Image Ranji Variability and Repeatability Tests of ARMD Assessment Using the AD3RI Tool, p.583 ,
