Recursive nearest agglomeration (ReNA): fast clustering for approximation of structured signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 2016
In this work, we revisit fast dimension reduction approaches, as with random projections and random sampling. Our goal is to summarize the data to decrease computational costs and memory footprint of subsequent analysis. Such dimension reduction can be very efficient when the signals of interest have a strong structure, such as with images. We focus on this setting and investigate feature clustering schemes for data reductions that capture this structure. An impediment to fast dimension reduction is that good clustering comes with large algorithmic costs. We address it by contributing a linear-time agglomerative clustering scheme, Recursive Nearest Agglomeration (ReNA). Unlike existing fast agglomerative schemes, it avoids the creation of giant clusters. We empirically validate that it approximates the data as well as traditional variance-minimizing clustering schemes that have a quadratic complexity. In addition, we analyze signal approximation with feature clustering and show that it can remove noise, improving subsequent analysis steps. As a consequence, data reduction by clustering features with ReNA yields very fast and accurate models, enabling to process large datasets on budget. Our theoretical analysis is backed by extensive experiments on publicly-available data that illustrate the computation efficiency and the denoising properties of the resulting dimension reduction scheme.
paper.pdf (7.89 Mo) Télécharger le fichier
hal-01366651 , version 1 (15-09-2016)
hal-01366651 , version 2 (16-03-2018)
Andrés Hoyos-Idrobo, Gaël Varoquaux, Jonas Kahn, Bertrand Thirion. Recursive nearest agglomeration (ReNA): fast clustering for approximation of structured signals. IEEE Transactions on Pattern Analysis and Machine Intelligence, inPress, XX, ⟨10.1109/TPAMI.2018.2815524⟩. ⟨hal-01366651v2⟩
870 Consultations
365 Téléchargements
