A level set method for ductile fracture, Proceedings [IOS * 14] SPH Fluids in Computer Graphics, p.61 ,
Virtual time, ACM Trans. Program ,
Face offsetting: A unified approach for explicit 67 moving interfaces, J. Comput. Phys, vol.220, issue.2, pp.612-625, 2007. ,
Deformation embedding for point-based elasto- 71 plastic simulation Ocean waves animation using 73 boundary integral equations and explicit mesh tracking, ACM 74 SIGGRAPH 2014 Posters, pp.69-72, 2014. ,
Practi- 76 cal animation of turbulent splashing water, Proceedings of the 77 2006 ACM SIGGRAPH/Eurographics Symposium on Computer 78 ,
Fluid animation with dynamic meshes ,
Cable route plan- 84 ning in complex environments using constrained sampling, 85 Proceedings of the 2007 ACM Symposium on Solid and Physical 86 ,
Multi-phase fluid simulations using regional Timewarp rigid body simulation, Pro- 52 ceedings of the 27th Annual Conference on Computer Graph- 53 ics and Interactive Techniques 54 SIGGRAPH '00, pp.55-193, 2000. ,
Point based animation of elastic, 58 plastic and melting objects, Proceedings of the 2004 ACM 59 SIGGRAPH/Eurographics Symposium on Computer Animation SCA '04, Eurographics Association, pp.141-151, 2004. ,
Modeling water for computer 69 graphics Folding and 71 crumpling adaptive sheets, Computers & Graphics ACM Trans. Graph, vol.21, issue.51, pp.68-801, 1997. ,
Adaptive 74 anisotropic remeshing for cloth simulation, ACM Trans. Graph, vol.75, issue.9, pp.73-311, 2012. ,
Adaptive deformations with fast tight bounds, Proceed- 78 ings of the 2007 ACM SIGGRAPH/Eurographics Symposium on 79 Computer Animation SCA '07, Eurographics Associa- 80 tion, pp.76-181, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-01148393
Dynamic simulation 82 of splashing fluids, Proceedings of the Computer Animation CA '95, pp.81-198, 1995. ,
Temporal blending for, p.85 ,
FED- 88 KIW R.: A hybrid lagrangian-eulerian formulation for bubble 89 generation and dynamics, Proceedings of the 12th ACM 90 SIGGRAPH/Eurographics Symposium on Computer Animation SCA '13, ACM, pp.105-114, 2013. ,
Meshless animation of fracturing 94 solids, ACM Trans. Graph, vol.24, issue.3, pp.957-964, 2005. ,
Collision and self-collision handling in cloth 99 model dedicated to design garments In Computer Animation 100 and Simulation '97, Eu- 101 rographics, pp.177-189, 1997. ,
Adaptive dynam- 103 ics of articulated bodies, ACM Trans. Graph, vol.102, issue.6, pp.936-945, 2005. ,
Embedded thin shells for 106 wrinkle simulation, ACM Transactions on Graphics, vol.32, issue.4 ,
Two-way coupling of fluids to 113 rigid and deformable solids and shells, ACM Transactions 114 on Graphics (TOG), pp.46-66, 2008. ,
Optimization-based animation. PhD the- 116 sis, The University of Miami, 2002. ,
Elastically deformable models, SIGGRAPH Comput. Graph, vol.64, issue.21 4 1, pp.205-214, 1987. ,
Asyn- 66 chronous cloth simulation, Computer Graphics International, vol.67, issue.5, 2008. ,
Anima- 69 tion of open water phenomena with coupled shallow water and 70 free surface simulations Adaptive meshing for 74 cloth animation, Proceedings of the 2006 ACM 71 SIGGRAPH/Eurographics Symposium on Computer Animation SCA '06, Eurographics Association, pp.68-157, 2005. ,
Adaptive nonlinear finite elements for deformable body sim- 78 ulation using dynamic progressive meshes, Computer Graphics Forum, vol.79, issue.8, pp.76-349, 2001. ,
Interactive high- 81 resolution boundary surfaces for deformable bodies with chang- 82 ing topology, Proceedings of 8th Workshop on Virtual Real- 83 ,
Efficient colli- 86 sion detection for composite finite element simulation of cuts in 87 deformable bodies. The Visual Computer, Proc. CGI 2013), pp.6-8, 2013. ,
An 90 adaptive virtual node algorithm with robust mesh cutting, p.18 ,
Dynamic local remesh- 93 ing for elastoplastic simulation, ACM Trans. Graph, vol.29, issue.12, pp.1-4911, 1994. ,
Fast viscoelastic behavior with 96 thin features, ACM Trans. Graph, vol.27, issue.10, pp.951-998, 2008. ,
Physically- 99 based simulation of cuts in deformable bodies: A survey, p.98 ,
Real-time hap- 103 tic cutting of high resolution soft tissues, Studies in Health Tech- 104 nology and Informatics (Proc. Medicine Meets Virtual Reality, pp.469-475, 2014. ,
A 115 new grid structure for domain extension, ACM Trans. Graph, vol.32, issue.63, pp.116-157, 2013. ,
Codimensional surface tension flow on simplicial com- 119 plexes Adap- 121 tive sampling and rendering of fluids on the gpu, Proceed- 122 ings of the Fifth Eurographics, pp.1-111, 2014. ,
