Swirling-sweepers: Constant-volume modeling, Graph. Models, vol.68, issue.4, pp.324-332, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00402557
Deformable object animation using reduced optimal control, ACM Trans. Graph, vol.28, issue.53, pp.1-53, 2009. ,
Interactive editing of deformable simulations, ACM Trans. Graph, vol.31, issue.70, pp.1-70, 2012. ,
Geometric modeling based on polygonal meshes video files associated with this course are available from the citation page, ACM SIGGRAPH 2007 Courses, 2007. ,
Sampling plausible solutions to multi-body constraint problems, Proceedings of the 27th Annual Conference on Computer Graphics and Interactive Techniques, pp.219-228, 2000. ,
Target-driven smoke animation, ACM Trans. Graph, vol.23, issue.3, pp.441-448, 2004. ,
Interactive Animation of Ocean Waves, ACM-SIGGRAPH -EG Symposium on Computer Animation (SCA'02), 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00537490
Controlling fluid animation with geometric potential: Research articles, Comput. Animat. Virtual Worlds, vol.15, pp.3-4, 2004. ,
Automated sampling and control of gaseous simulations, The Visual Computer, vol.29, pp.6-8, 2013. ,
Unified spray, foam and air bubbles for particle-based fluids, Vis. Comput, vol.28, pp.6-8, 2012. ,
Water wave animation via wavefront parameter interpolation, ACM Transactions on Graphics (TOG), vol.34, issue.3, p.27, 2015. ,
Path-based control of smoke simulations, Proceedings of the 2006 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.33-42, 2006. ,
Space-time editing of elastic motion through material optimization and reduction, ACM Trans. Graph, vol.33, issue.108, pp.1-10810, 2014. ,
Target particle control of smoke simulation, Proceedings of Graphics Interface 2013, pp.125-132, 2013. ,
Fluid control using the adjoint method, ACM Trans. Graph, vol.23, issue.3, pp.449-456, 2004. ,
Feature-guided dynamic texture synthesis on continuous flows, Proceedings of the 18th Eurographics Conference on Rendering Techniques, Eurographics Association, pp.7-361, 2007. ,
Guide shapes for high resolution naturalistic liquid simulation, ACM Trans. Graph, vol.30, issue.83, pp.1-83, 2011. ,
Improved variational guiding of smoke animations, Computer Graphics Forum, vol.29, issue.2, pp.705-712, 2010. ,
Guiding of smoke animations through variational coupling of simulations at different resolutions, Proceedings of the 2009 ACM SIG- GRAPH/Eurographics Symposium on Computer Animation, pp.217-226, 2009. ,
Interactive localized liquid motion editing, ACM Trans. Graph, vol.32, issue.184, pp.1-18410, 2013. ,
Modeling and editing flows using advected radial basis functions, Proceedings of the 2004 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.223-232, 2004. ,
Interactive manipulation of rigid body simulations, Proceedings of the 27th Annual Conference on Computer Graphics and Interactive Techniques, pp.209-217, 2000. ,
Controlling liquids using meshes, Proceedings of the ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.255-264, 2012. ,
Blending liquids, ACM Trans. Graph, vol.33, issue.137, pp.1-13710, 2014. ,
Simulating rivers in the good dinosaur, ACM SIGGRAPH 2016 Talks, pp.1-40, 2016. ,
Meshmixer: an interface for rapid mesh composition, ACM SIGGRAPH 2010 Talks, 2010. ,
Modeling and animating gases with simulation features, Proceedings of the 2005 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.97-105, 2005. ,
Animating deformable objects using sparse spacetime constraints, ACM Trans. Graph, vol.33, issue.109, pp.1-10910, 2014. ,
Controllable smoke animation with guiding objects, ACM Trans. Graph, vol.24, issue.1, pp.140-164, 2005. ,
Taming liquids for rapidly changing targets, Proceedings of the 2005 ACM SIG- GRAPH/Eurographics Symposium on Computer Animation, pp.229-236, 2005. ,
Freestyle: Sculpting meshes with self-adaptive topology, Computers & Graphics, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00606516
Realistic animation of fluid with splash and foam, Computer Graphics Forum, vol.22, issue.3, pp.391-400, 2003. ,
Geobrush: Interactive mesh geometry cloning, Computer Graphics Forum (proceedings of EUROGRAPHICS), vol.30, issue.2, pp.613-622, 2011. ,
Keyframe control of smoke simulations, ACM Trans. Graph, vol.22, issue.3, pp.716-723, 2003. ,
Many-worlds browsing for control of multibody dynamics, ACM Trans. Graph, vol.26, p.3, 2007. ,
Large scale simulation and surfacing of water and ice effects in Dragons 2, ACM SIGGRAPH 2014 Talks on, SIGGRAPH '14, pp.141-152, 2014. ,
DOI : 10.1145/2614106.2614156
Vector field based shape deformations, In ACM TOG, proc. of SIG- GRAPH, 2006. ,
Spacetime constraints, Proceedings of the 15th Annual Conference on Computer Graphics and Interactive Techniques, pp.159-168, 1988. ,
Keyframe control of complex particle systems using the adjoint method, Proceedings of the 2006 ACM SIGGRAPH/Eurographics symposium on Computer animation, Eurographics Association, pp.15-23, 2006. ,
Technical section: A unified smoke control method based on signed distance field, Comput. Graph, vol.37, issue.7, pp.775-786, 2013. ,
Pattern-guided smoke animation with lagrangian coherent structure, ACM Trans. Graph, vol.30, issue.136, pp.1-1368, 2011. ,
Animating sand as a fluid, In ACM Transactions on Graphics (TOG), vol.24, pp.965-972, 2005. ,
