Heterogeneous Face Recognition with CNNs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Heterogeneous face recognition aims to recognize faces across different sensor modalities. Typically, gallery images are normal visible spectrum images, and probe images are infrared images or sketches. Recently significant improvements in visible spectrum face recognition have been obtained by CNNs learned from very large training datasets. In this paper, we are interested in the question to what extent the features from a CNN pre-trained on visible spectrum face images can be used to perform heterogeneous face recognition. We explore different metric learning strategies to reduce the discrepancies between the different modalities. Experimental results show that we can use CNNs trained on visible spectrum images to obtain results that are on par or improve over the state-of-the-art for heterogeneous recognition with near-infrared images and sketches.
0014.pdf (1.48 Mo) Télécharger le fichier
hal-01367455 , version 1 (16-09-2016)
Shreyas Saxena, Jakob Verbeek. Heterogeneous Face Recognition with CNNs. ECCV TASK-CV 2016 Workshops, Oct 2016, Amsterdam, Netherlands. pp.483-491, ⟨10.1007/978-3-319-49409-8_40⟩. ⟨hal-01367455⟩
796 Consultations
2096 Téléchargements
