Subspace Identification for Linear Systems: Theory, 1996. ,
DOI : 10.1007/978-1-4613-0465-4
System Identification Methods for (Operational) Modal Analysis: Review and Comparison, Archives of Computational Methods in Engineering, vol.15, issue.5, pp.51-124, 2012. ,
DOI : 10.1007/s11831-012-9069-x
Fast multi-order computation of system matrices in subspace-based system identification, Control Engineering Practice, vol.20, issue.9, pp.882-894, 2012. ,
DOI : 10.1016/j.conengprac.2012.05.005
REFERENCE-BASED STOCHASTIC SUBSPACE IDENTIFICATION FOR OUTPUT-ONLY MODAL ANALYSIS, Mechanical Systems and Signal Processing, vol.13, issue.6, pp.855-878, 1999. ,
DOI : 10.1006/mssp.1999.1249
Covariance-driven subspace methods: input/output vs. output-only, Proceedings of the 21st International Modal Analysis Conference, 2003. ,
Input/output versus output-only data processing for structural identification???Application to in-flight data analysis, Journal of Sound and Vibration, vol.295, issue.3-5, pp.531-552, 2006. ,
DOI : 10.1016/j.jsv.2006.01.039
Modular Subspace-Based System Identification From Multi-Setup Measurements, IEEE Transactions on Automatic Control, vol.57, issue.11, pp.2951-2956, 2012. ,
DOI : 10.1109/TAC.2012.2193711
Input-Output Subspace-Based Fault Detection*, Proc. 8th IFAC Symposium on fault detection, diagnosis and safety of technical processes (SAFEPROCESS), pp.204-209, 2012. ,
DOI : 10.3182/20120829-3-MX-2028.00113
URL : https://hal.archives-ouvertes.fr/hal-00695619
Covariance-driven subspace identification: A complete input???output approach, Journal of Sound and Vibration, vol.332, issue.26, pp.7000-7017, 2013. ,
DOI : 10.1016/j.jsv.2013.08.025
Uncertainty calculation in (operational) modal analysis, Mechanical Systems and Signal Processing, pp.2359-2373, 2007. ,
DOI : 10.1016/j.ymssp.2006.11.007
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
DOI : 10.1016/j.ymssp.2007.10.009
Efficient multi-order uncertainty computation for stochastic subspace identification, Mechanical Systems and Signal Processing, vol.38, issue.2, pp.346-366, 2013. ,
DOI : 10.1016/j.ymssp.2013.01.012
Uncertainty quantification for modal parameters from stochastic subspace identification on multi-setup measurements, Mechanical Systems and Signal Processing, vol.36, issue.2, pp.562-581, 2013. ,
DOI : 10.1016/j.ymssp.2012.11.011
Structural health monitoring with statistical methods during progressive damage test of S101 Bridge, Engineering Structures, vol.69, pp.183-193, 2014. ,
DOI : 10.1016/j.engstruct.2014.03.010
Variance estimation of modal parameters from output-only and input/output subspace-based system identification, Journal of Sound and Vibration, vol.379, pp.1-27, 2016. ,
DOI : 10.1016/j.jsv.2016.05.037
URL : https://hal.archives-ouvertes.fr/hal-01328435
Reference-based combined deterministic???stochastic subspace identification for experimental and operational modal analysis, Mechanical Systems and Signal Processing, vol.22, issue.3, pp.617-637, 2008. ,
DOI : 10.1016/j.ymssp.2007.09.004
Identification of the deterministic part of MIMO state space models given in innovations form from input-output data, Special issue on statistical signal processing and control, pp.61-74, 1994. ,
DOI : 10.1016/0005-1098(94)90229-1
Matrix computations, 1996. ,
Statistical Inference., Biometrics, vol.49, issue.1, 2002. ,
DOI : 10.2307/2532634
Damage Detection in Wind Turbine Blade Panels Using Three Different SHM Techniques, Proc. 28th International Modal Analysis Conference, 2010. ,
DOI : 10.1007/978-1-4419-9716-6_12
URL : https://hal.archives-ouvertes.fr/inria-00531345
