Some Questions in the Theory of Moments, 1962. ,
On General Domain Truncated Correlation and Convolution Operators with Finite Rank. Integral Equations and Operator Theory, pp.339-370, 2015. ,
On the structure of positive semi-definite finite rank general domain Hankel and Toeplitz operators in several variables. Complex Analysis and Operator Theory, 2016. ,
Nonlinear approximation of functions in two dimensions by sums of wave packets, Applied and Computational Harmonic Analysis, vol.29, issue.2, pp.198-213, 2010. ,
DOI : 10.1016/j.acha.2009.09.001
Padé Approximants, 1996. ,
Sur la réalisation de Nerode des systèmes multi-indiciels, C. R. Acad. Sc. Paris, vol.301, pp.715-718, 1984. ,
On the Accuracy of Solving Confluent Prony Systems, SIAM Journal on Applied Mathematics, vol.73, issue.1, pp.134-154, 2013. ,
DOI : 10.1137/110836584
On the numerical condition of a generalized Hankel eigenvalue problem, Numerische Mathematik, vol.13, issue.3, pp.41-68, 2007. ,
DOI : 10.1007/978-3-662-03329-6
A Uniform Approach for the Fast Computation of Matrix-Type Pad?? Approximants, SIAM Journal on Matrix Analysis and Applications, vol.15, issue.3, pp.804-823, 1994. ,
DOI : 10.1137/S0895479892230031
A deterministic algorithm for sparse multivariate polynomial interpolation, Proceedings of the twentieth annual ACM symposium on Theory of computing , STOC '88, pp.301-309, 1988. ,
DOI : 10.1145/62212.62241
Nonbinary BCH decoding (Abstr.), IEEE Transactions on Information Theory, vol.14, issue.2, pp.242-242, 1968. ,
DOI : 10.1109/TIT.1968.1054109
General tensor decomposition, moment matrices and applications, Journal of Symbolic Computation, vol.52, pp.51-71, 2013. ,
DOI : 10.1016/j.jsc.2012.05.012
URL : https://hal.archives-ouvertes.fr/inria-00590965
Linear Algebra for Computing Gröbner Bases of Linear Recursive Multidimensional Sequences, International Symposium on Symolic and Algebraic Compution, pp.61-68, 2015. ,
On approximation of functions by exponential sums, Applied and Computational Harmonic Analysis, vol.19, issue.1, pp.17-48, 2005. ,
DOI : 10.1016/j.acha.2005.01.003
Symmetric tensor decomposition . Linear Algebra and Applications, pp.1851-1872, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00435908
Stable signal recovery from incomplete and inaccurate measurements, Communications on Pure and Applied Mathematics, vol.7, issue.8, pp.1207-1223, 2006. ,
DOI : 10.1017/CBO9780511804441
¨ Uber den Zusammenhang der Extremen von Harmonischen Funktionen mit Ihren Koeffizienten und¨Uberund¨ und¨Uber den Picard-Landauschen Satz, Rendiconti del Circolo Matematico di Paler mo, pp.218-239, 1884. ,
Ideals, Varieties, and Algorithms, Undergraduate Texts in Mathematics, 1992. ,
Solution of the Truncated Complex Moment Problem for Flat Data, 1996. ,
How well can the concept of Pad?? approximant be generalized to the multivariate case?, Journal of Computational and Applied Mathematics, vol.105, issue.1-2, pp.25-50, 1999. ,
DOI : 10.1016/S0377-0427(99)00028-X
Essai expérimental et analytique: sur les lois de la dilatabilité de fluidesélastiquefluidesélastique et sur celles de la force expansive de la vapeur de l'alcool, ` a différentes températures, J. ´ Ecole Polytechnique, vol.1, pp.24-76 ,
Commutative Algebra: With a View toward Algebraic Geometry, volume 150 of Graduate texts in mathematics, 1994. ,
DOI : 10.1007/978-1-4612-5350-1
IntroductionàIntroduction`Introductionà la résolution des systèmes polynomiaux, of Mathématiques & Applications, 2007. ,
Géométrie des pointsépaispointsépais, Bulletin de la S.M.F, vol.106, pp.399-416, 1978. ,
??ber das carath??odory???sche problem, potenzreihen mit positivem reellen teil betreffend, Rendiconti del Circolo Matematico di Palermo, vol.32, issue.1, pp.240-256, 1911. ,
DOI : 10.1007/BF03014797
Finding a basis for the characteristic ideal of an n-dimensional linear recurring sequence, IEEE Transactions on Information Theory, vol.36, issue.6, pp.1480-1487, 1990. ,
DOI : 10.1109/18.59953
Symbolic???numeric sparse interpolation of multivariate polynomials, Journal of Symbolic Computation, vol.44, issue.8, pp.943-959, 2009. ,
DOI : 10.1016/j.jsc.2008.11.003
Separable nonlinear least squares: the variable projection method and its applications, Inverse Problems, vol.19, issue.2, pp.1-26, 2003. ,
DOI : 10.1088/0266-5611/19/2/201
2D-Extension of Singular Spectrum Analysis: Algorithm and Elements of Theory, Matrix Methods: Theory, Algorithms and Applications, pp.449-473, 2010. ,
DOI : 10.1142/9789812836021_0029
A new algorithm for computing certified numerical approximations of the roots of a zero-dimensional system, Proceedings of the 2009 international symposium on Symbolic and algebraic computation, ISSAC '09, pp.167-174, 2009. ,
DOI : 10.1145/1576702.1576727
URL : https://hal.archives-ouvertes.fr/hal-01294713
Uber das Macaulaysche inverse System und dessen Bedeutung für die Theorie der linearen Differentialgleichungen mit konstanten Koeffizienten, Abhandlungen Aus Dem Mathematischen Seminar Der Universität Hamburg, pp.127-132, 1937. ,
Finite rank Hankel operators on the polydisk, Linear Algebra and its Applications, vol.288, pp.269-281, 1999. ,
DOI : 10.1016/S0024-3795(98)10223-9
Partial differential analogs of ordinary differential equations and systems, New York J. Math, vol.10, pp.89-116, 2004. ,
An Introduction to Complex Analysis in Several Variables, 1990. ,
Power Sums, Gorenstein Algebras, and Determinantal Loci, Lecture Notes in Mathematics, vol.1721, 1999. ,
DOI : 10.1007/BFb0093426
Zur Theorie der Elimination Einer Variabeln aus Zwei Algebraischen Gleichungen, pp.535-600, 1880. ,
A multivariate generalization of Prony's method, Linear Algebra and its Applications, vol.490, pp.31-47, 2016. ,
DOI : 10.1016/j.laa.2015.10.023
Moment matrices, border bases and real radical computation, Journal of Symbolic Computation, vol.51, pp.63-85, 2013. ,
DOI : 10.1016/j.jsc.2012.03.007
URL : https://hal.archives-ouvertes.fr/hal-01282654
Sums of Squares, Moment Matrices and Optimization Over Polynomials, Emerging Applications of Algebraic Geometry, pp.157-270, 2009. ,
DOI : 10.1007/978-0-387-09686-5_7
A generalized flat extension theorem for moment matrices, Archiv der Mathematik, vol.38, issue.1, pp.87-98, 2009. ,
DOI : 10.1017/S0017089501030130
Blind Multilinear Identification, IEEE Transactions on Information Theory, vol.60, issue.2, pp.1260-1280, 2014. ,
DOI : 10.1109/TIT.2013.2291876
URL : https://hal.archives-ouvertes.fr/hal-00763275
The Algebraic Theory of Modular Systems, 1916. ,
The Theory of Error-Correcting Codes, 1977. ,
Existence et approximation des solutions deséquationsdeséquations aux dérivées partielles et deséquationsdeséquations de convolution. Annales de l'institut Fourier, pp.271-355, 1956. ,
Shift-register synthesis and BCH decoding, IEEE Transactions on Information Theory, vol.15, issue.1, pp.122-127, 1969. ,
DOI : 10.1109/TIT.1969.1054260
Isolated points, duality and residues, Journal of Pure and Applied Algebra, vol.117, issue.118, pp.469-493, 1996. ,
DOI : 10.1016/S0022-4049(97)00023-6
URL : https://hal.archives-ouvertes.fr/inria-00125278
A New Criterion for Normal Form Algorithms, Proc. AAECC, pp.430-443, 1999. ,
DOI : 10.1007/3-540-46796-3_41
Multivariate Polynomials, Duality, and Structured Matrices, Multivariate Polynomials, Duality, and Structured Matrices, pp.110-180, 2000. ,
DOI : 10.1006/jcom.1999.0530
URL : https://hal.archives-ouvertes.fr/inria-00073171
Generalized normal forms and polynomial system solving, Proceedings of the 2005 international symposium on Symbolic and algebraic computation , ISSAC '05, pp.253-260, 2005. ,
DOI : 10.1145/1073884.1073920
URL : https://hal.archives-ouvertes.fr/inria-00070537
The Constructive Solution of Linear Systems of Partial Difference and Differential Equations with Constant Coefficients, Multidimensional Systems and Signal Processing, pp.3-4253, 2001. ,
Basis for Power Series Solutions to Systems of Linear, Constant Coefficient Partial Differential Equations, Advances in Mathematics, vol.141, issue.1, pp.155-166, 1999. ,
An excursion into the theory of Hankel operators Holomorphic spaces, Math. Sci. Res. Inst. Publ, vol.33, pp.65-120, 1995. ,
A generalized Prony method for reconstruction of sparse sums of eigenfunctions of linear operators, Inverse Problems, vol.29, issue.2, p.25001, 2013. ,
DOI : 10.1088/0266-5611/29/2/025001
Prony methods for recovery of structured functions. GAMM- Mitteilungen, pp.239-258, 2014. ,
Parameter estimation for exponential sums by approximate Prony method, Signal Processing, vol.90, issue.5, pp.1631-1642, 2010. ,
DOI : 10.1016/j.sigpro.2009.11.012
Parameter estimation for multivariate exponential sums, Electronic Transactions on Numerical Analysis, vol.40, pp.204-224, 2013. ,
Finite rank multivariable Hankel forms, Linear Algebra and its Applications, vol.48, pp.237-244, 1982. ,
DOI : 10.1016/0024-3795(82)90110-0
Les systèmes d'´ equations aux dérivées partielles, volume XXVII, 1910. ,
Toeplitz and Hankel operators on the Paley-Wiener space. Integral Equations and Operator Theory, pp.187-235, 1987. ,
Signal processing part II. chapter ESPRIT-estimation of signal parameters via rotational invariance techniques, pp.369-411, 1990. ,
Finding a minimal set of linear recurring relations capable of generating a given finite two-dimensional array, Journal of Symbolic Computation, vol.5, issue.3, pp.321-337, 1988. ,
DOI : 10.1016/S0747-7171(88)80033-6
Prony???s method in several variables, Numerische Mathematik, vol.30, issue.4, pp.411-438, 2017. ,
DOI : 10.1090/cbms/097
Théorie des distributions, Editions Hermann, 1966. ,
A Performance Analysis of Subspace-Based Methods in the Presence of Model Errors ? Part I: The MUSIC Algorithm, IEEE Trans. on Signal Processing, vol.40, pp.1758-1774, 1992. ,
Essay on Canonical Form. The collected mathematical papers of, p.1851, 1909. ,
Modern Computer Algebra, 2013. ,
Vandermonde Decomposition of Multilevel Toeplitz Matrices With Application to Multidimensional Super-Resolution, IEEE Transactions on Information Theory, vol.62, issue.6, pp.3685-3701, 2016. ,
DOI : 10.1109/TIT.2016.2553041
Probabilistic algorithms for sparse polynomials, Proceedings of the International Symposiumon on Symbolic and Algebraic Computation, EUROSAM '79, pp.216-226, 1979. ,
DOI : 10.1007/3-540-09519-5_73
