Model-based co-clustering for hyperspectral images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Spectral Imaging Année : 2016
A model-based co-clustering algorithm for hyperspectral images is presented. This algorithm, which relies on the probabilistic latent block model for continuous data, aims to cluster both the pixels and the spectral features of the images. This approach has been applied to a benchmark Raman imaging dataset and revealed relevant information for spatial-spectral exploratory investigation of the data.
Coclustering4HSI.pdf (2.87 Mo) Télécharger le fichier
hal-01367941 , version 1 (17-09-2016)
Julien Jacques, Cyril Ruckebusch. Model-based co-clustering for hyperspectral images. Journal of Spectral Imaging, 2016, 5, pp.a3-1 - a3-6. ⟨10.1255/jsi.2016.a3⟩. ⟨hal-01367941⟩
274 Consultations
167 Téléchargements
