New interface
Journal articles
Congested shallow water model: roof modelling in free surface flow
Abstract : We are interested in the modeling and the numerical approximation of flows in the presence of a roof, for example flows in sewers or under an ice floe. A shallow water model with a supplementary congestion constraint describing the roof is derived from the Navier-Stokes equations. The congestion constraint is a challenging problem for the numerical resolution of hyperbolic equations. To overcome this difficulty, we follow a pseudo-compressibility relaxation approach. Eventually, a numerical scheme based on a Finite Volume method is proposed. The well-balanced property and the dissipation of the mechanical energy, acting as a mathematical entropy, are ensured under a non-restrictive condition on the time step in spite of the large celerity of the potential waves in the congested areas. Simulations in one dimension for transcritical steady flow are carried out and numerical solutions are compared to several analytical (stationary and non-stationary) solutions for validation.
Complete list of metadata
Cited literature [47 references]  Display  Hide  Download
https://hal.inria.fr/hal-01368075
Contributor : Fabien Wahl Connect in order to contact the contributor
Submitted on : Friday, May 11, 2018 - 10:44:11 AM
Last modification on : Friday, July 8, 2022 - 10:05:53 AM
File
PFSF_V_4.0.pdf
Identifiers
Citation
Edwige Godlewski, Martin Parisot, Jacques Sainte-Marie, Fabien Wahl. Congested shallow water model: roof modelling in free surface flow. ESAIM: Mathematical Modelling and Numerical Analysis, 2018, 52 (5), pp.1679 - 1707. ⟨10.1051/m2an/2018032⟩. ⟨hal-01368075v3⟩
Share
Metrics
Record views
1135
Files downloads
548
