New interface
Conference papers
Input and State Observability of Network Systems with a Single Unknown Input
Alain Kibangou 1 Federica Garin 1 Sebin Gracy 1
1 NECS - Networked Controlled Systems
Inria Grenoble - Rhône-Alpes, GIPSA-DA - Département Automatique
Abstract : This paper studies network systems affected by a single unknown input, possibly representing an attack or a failure, to be estimated. The main result is a characterization of input and state observability, namely the conditions under which both the whole network state and the unknown input can be reconstructed from some measured local states. This characterization is in terms of observability of a suitably-defined subsystem, which allows the use of known graphical charactizations of observability of network systems, leading to structural results (true for almost all interaction weights) or strong structural results (true for all non-zero interaction weights). We apply our results to an illustrative example, finding a full characterization of input and state observability of a path graph, affected by a single unknown input and with measurement of a small number of local states.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01368906
Contributor : Federica Garin Connect in order to contact the contributor
Submitted on : Tuesday, September 20, 2016 - 11:32:37 AM
Last modification on : Friday, February 4, 2022 - 3:24:29 AM
File
NecSys2016-final.pdf
Identifiers
  • HAL Id : hal-01368906, version 1
Collections
Citation
Alain Kibangou, Federica Garin, Sebin Gracy. Input and State Observability of Network Systems with a Single Unknown Input. NecSys 2016 - 6th IFAC Workshop on Distributed Estimation and Control in Networked Systems, IFAC, Sep 2016, Tokyo, Japan. ⟨hal-01368906⟩
Share
Metrics
Record views
219
Files downloads
200
