Sea of images, pp.331-338, 2002. ,
Large-scale point-cloud visualization through localized textured surface reconstruction, IEEE Trans. Vis. Comput. Graphics, vol.20, issue.9, pp.1280-1292, 2014. ,
Multi-depthmap raytracing for efficient large-scene reconstruction, IEEE Trans. Vis. Comput. Graphics, vol.22, issue.2, pp.1127-1137, 2016. ,
Efficient large scale acquisition of building interiors, Comp. Graph Forum, vol.25, issue.3, pp.655-662, 2006. ,
Using photographs to enhance videos of a static scene, EGSR, Eurographics Association, pp.327-338, 2007. ,
Rendering gigaray light fields, Comp. Graph. Forum, vol.32, issue.2, pp.469-478, 2013. ,
Unstructured lumigraph rendering, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.425-432, 2001. ,
DOI : 10.1145/383259.383309
Depth synthesis and local warps for plausible image-based navigation, ACM Trans. Graph, vol.32, issue.30, pp.1-3012, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00907793
Light field mapping: efficient representation and hardware rendering of surface light fields, ACM Trans. Graph, vol.21, issue.3, pp.447-456, 2002. ,
Robust reconstruction of indoor scenes, CVPR, IEEE, pp.5556-5565, 2015. ,
A large dataset of object scans, 2016. ,
BundleFusion: Real-time globally consistent 3D reconstruction using online surface re-integration, 2016. ,
Unstructured light fields, Comp. Graph. Forum, vol.31, issue.2, pp.305-314, 2012. ,
Efficient view-dependent image-based rendering with projective texturemapping, Rendering Workshop, pp.105-116, 1998. ,
Floating textures, Comp. Graph. Forum, vol.27, issue.2, pp.409-418, 2008. ,
Image-based rendering using image-based priors, Int. J. Comput. Vision, vol.63, issue.2, pp.141-151, 2005. ,
DeepStereo: Learning to predict new views from the world's imagery, pp.5515-5524, 2016. ,
Accurate, dense, and robust multiview stereopsis, IEEE Trans. Pattern Anal. Mach. Intell, vol.32, issue.8, pp.1362-1376, 2010. ,
Reconstructing building interiors from images, pp.80-87, 2009. ,
Massively parallel multiview stereopsis by surface normal diffusion, pp.873-881, 2015. ,
Surface simplification using quadric error metrics, SIGGRAPH, ACM, pp.209-216, 1997. ,
Multi-view stereo for community photo collections, pp.1-8, 2007. ,
Ambient point clouds for view interpolation, ACM Trans. Graph, vol.29, issue.95, pp.1-95, 2010. ,
A Super-Resolution Framework for High-Accuracy Multiview Reconstruction, International Journal of Computer Vision, vol.13, issue.4, pp.172-191, 2014. ,
DOI : 10.1007/s11263-013-0654-8
The lumigraph, SIGGRAPH, ACM, pp.43-54, 1996. ,
RGB-D mapping: Using Kinect-style depth cameras for dense 3D modeling of indoor environments, Int. J. Rob. Res, vol.5, pp.31-647, 2012. ,
Screened poisson surface reconstruction, ACM Trans. Graph, vol.32, issue.29, pp.1-2913, 2013. ,
Image-based rendering in the gradient domain, ACM Trans. Graph, vol.32, issue.199, pp.1-199, 2013. ,
A silhouette-based algorithm for texture registration and stitching, Graph. Models, vol.63, issue.4, pp.245-262, 2001. ,
Image-based reconstruction of spatial appearance and geometric detail, ACM Trans. Graph, vol.22, issue.2, pp.234-257, 2003. ,
Light field rendering, SIGGRAPH, ACM, pp.31-42, 1996. ,
Constant time weighted median filtering for stereo matching and beyond, pp.49-56, 2013. ,
Image-based visual hulls, SIGGRAPH, ACM, pp.369-374, 2000. ,
Plenoptic modeling: An image-based rendering system, SIGGRAPH, ACM, pp.39-46, 1995. ,
Adaptive structure from motion with a contrario model estimation, ACCV, pp.257-270, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00769266
A survey on time-of-flight stereo fusion, Time-of-Flight and Depth Imaging. Sensors, Algorithms, and Applications, pp.105-127, 2013. ,
KinectFusion: Real-time dense surface mapping and tracking, ISMAR, pp.127-136, 2011. ,
Real-time 3D reconstruction at scale using voxel hashing, ACM Trans. Graph, vol.32, issue.169, pp.1-16911, 2013. ,
Tiled shading, J. Graphics, GPU, and Game Tools, vol.15, issue.4, pp.235-251, 2011. ,
A Bayesian approach for selective image-based rendering using superpixels, 3DV, IEEE, pp.469-477, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01207907
Bayesian view synthesis and image-based rendering principles, pp.3906-3913, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00983315
Capturing indoor scenes with smartphones, UIST, ACM, pp.403-412, 2012. ,
Image-based rendering, 2008. ,
Piecewise planar stereo for image-based rendering, pp.1881-1888, 2009. ,
Perception-motivated interpolation of image sequences, ACM Trans. Applied Perception, vol.8, issue.2 11, pp.1-1125, 2011. ,
Image-based interactive exploration of real-world environments, IEEE Comput. Graph. Appl, vol.24, issue.3, pp.52-63, 2004. ,
Robust fitting on poorly sampled data for surface light field rendering and image relighting, Comp. Graph. Forum, vol.32, issue.6, pp.101-112, 2013. ,
Automatic view selection using viewpoint entropy and its application to image-based modelling, Comp. Graph. Forum, vol.22, issue.4, pp.689-700, 2003. ,
Let there be color! Large-scale texturing of 3D reconstructions, pp.836-850, 2014. ,
Multi-view depth map estimation with cross-view consistency, BMVC, 2014. ,
Surface light fields for 3D photography, SIGGRAPH, ACM, pp.287-296, 2000. ,
SUN3D: A database of big spaces reconstructed using SfM and object labels, pp.1625-1632, 2013. ,
Color map optimization for 3D reconstruction with consumer depth cameras, ACM Trans. Graph, vol.33, issue.155, pp.1-15510, 2014. ,
Elastic fragmens for dense scene reconstruction, Proc. ICCV, IEEE, pp.473-480, 2013. ,
Stereo for image-based rendering using image over-segmentation, Int. J. Comput. Vision, vol.75, issue.1, pp.49-65, 2007. ,
