An Information Flow-Based Taxonomy to Understand the Nature of Software Vulnerabilities
Despite the emphasis on building secure software, the number of vulnerabilities found in our systems is increasing every year, and well-understood vulnerabilities continue to be exploited. A common response to vulnerabilities is patch-based mitigation, which does not completely address the flaw and is often circumvented by an adversary. The problem actually lies in a lack of understanding of the nature of vulnerabilities. Vulnerability taxonomies have been proposed, but their usability is limited because of their ambiguity and complexity. This paper presents a taxonomy that views vulnerabilities as fractures in the interpretation of information as it flows in the system. It also presents a machine learning study validating the taxonomy’s unambiguity. A manually labeled set of 641 vulnerabilities trained a classifier that automatically categorized more than 70000 vulnerabilities from three distinct databases with an average success rate of 80 %. Important lessons learned are discussed such as (i) approximately 12 % of the studied reports provide insufficient information about vulnerabilities, and (ii) the roles of the reporter and developer are not leveraged, especially regarding information about tools used to find vulnerabilities and approaches to address them.
Informatique [cs]
