On SL(3,C)-representations of the Whitehead link group - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geometriae Dedicata Année : 2019
We describe a family of representations in SL(3,C) of the fundamental group π of the Whitehead link complement. These representations are obtained by considering pairs of regular order three elements in SL(3,C) and can be seen as factorising through a quotient of π defined by a certain exceptional Dehn surgery on the Whitehead link. Our main result is that these representations form an algebraic component of the SL(3,C)-character variety of π.
comp-WLC-arxiv.pdf (369.69 Ko) Télécharger le fichier
coordinates.pdf (2.32 Ko) Télécharger le fichier
equations.pdf (35.85 Ko) Télécharger le fichier
link.pdf (2.79 Ko) Télécharger le fichier
matrice.pdf (76.92 Ko) Télécharger le fichier
octa-hyp-2.pdf (20.43 Ko) Télécharger le fichier
octa-hyp.pdf (18.24 Ko) Télécharger le fichier
hal-01370289 , version 1 (22-09-2016)
Antonin Guilloux, Pierre Will. On SL(3,C)-representations of the Whitehead link group. Geometriae Dedicata, 2019, 202, pp.81-101. ⟨10.1007/s10711-018-0404-8⟩. ⟨hal-01370289⟩
282 Consultations
2060 Téléchargements
