New interface
Journal articles
Using finite transducers for describing and synthesising structural time-series constraints
Nicolas Beldiceanu 1, 2 Mats Carlsson 3 Rémi Douence 4 Helmut Simonis 5
1 TASC - Theory, Algorithms and Systems for Constraints
LINA - Laboratoire d'Informatique de Nantes Atlantique, Département informatique - EMN, Inria Rennes – Bretagne Atlantique
4 ASCOLA - Aspect and composition languages
Abstract : We describe a large family of constraints for structural time series by means of function composition. These constraints are on aggregations of features of patterns that occur in a time series, such as the number of its peaks, or the range of its steepest ascent. The patterns and features are usually linked to physical properties of the time series generator, which are important to capture in a constraint model of the system, i.e. a conjunction of constraints that produces similar time series. We formalise the patterns using finite transducers, whose output alphabet corresponds to semantic values that precisely describe the steps for identifying the occurrences of a pattern. Based on that description, we automatically synthesise automata with accumulators, as well as constraint checkers. The description scheme not only unifies the structure of the existing 30 time-series constraints in the Global Constraint Catalogue, but also leads to over 600 new constraints, with more than 100,000 lines of synthesised code.
Complete list of metadata
Cited literature [26 references]  Display  Hide  Download
https://hal.inria.fr/hal-01370322
Contributor : Contraintes Lina Connect in order to contact the contributor
Submitted on : Thursday, September 22, 2016 - 1:17:39 PM
Last modification on : Friday, July 8, 2022 - 10:09:43 AM
File
time_series_journal.pdf
Identifiers
Citation
Nicolas Beldiceanu, Mats Carlsson, Rémi Douence, Helmut Simonis. Using finite transducers for describing and synthesising structural time-series constraints. Constraints, 2016, 21 (1), pp.19. ⟨10.1007/s10601-015-9200-3⟩. ⟨hal-01370322⟩
Share
Metrics
Record views
799
Files downloads
703
