Output error minimizing back and forth nudging method for initial state recovery, Systems & Control Letters, vol.94, pp.111-117, 2016. ,
DOI : 10.1016/j.sysconle.2016.06.002
URL : https://hal.archives-ouvertes.fr/hal-01216075
Stabilization of Elastic Systems by Collocated Feedback, Lecture Notes in Mathematics, vol.2124, 2015. ,
DOI : 10.1007/978-3-319-10900-8
Back and forth nudging algorithm for data assimilation problems . Comptes Rendus de l, Academie des Sciences, Série I (Mathematique), vol.340, pp.873-878, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00189644
A nudging-based data assimilation method: the Back and Forth Nudging (BFN) algorithm, Nonlinear Processes in Geophysics, vol.15, issue.2, pp.305-319, 2008. ,
DOI : 10.5194/npg-15-305-2008
URL : https://hal.archives-ouvertes.fr/hal-00331117
Global Carleman Estimates for Waves and Applications, Communications in Partial Differential Equations, vol.75, issue.5, pp.823-859, 2013. ,
DOI : 10.1137/S0363012999350298
URL : https://hal.archives-ouvertes.fr/hal-00633562
On-Line Parameter Estimation for Infinite-Dimensional Dynamical Systems, SIAM Journal on Control and Optimization, vol.35, issue.2, pp.678-713, 1997. ,
DOI : 10.1137/S0363012994270928
Exponential Convergence of an Observer Based on Partial Field Measurements for the Wave Equation, Mathematical Problems in Engineering, vol.2012, 2012. ,
DOI : 10.1016/j.matpur.2008.09.002
URL : https://hal.archives-ouvertes.fr/inria-00619504
Robust filtering for joint state-parameter estimation in distributed mechanical systems. Discrete and Continuous Dynamical Systems, Series A, pp.65-84, 2009. ,
Particle filter scheme with mutation for the estimation of time-invariant parameters in structural health monitoring applications. Structural Control and Health Monitoring, pp.1081-1095, 2013. ,
Nonlinear Least Squares for Inverse Problems, 2009. ,
DOI : 10.1007/978-90-481-2785-6
Time-varying additive perturbations of well-posed linear systems, Mathematics of Control, Signals, and Systems, vol.11, issue.2, pp.149-185, 2015. ,
DOI : 10.1007/s00498-014-0136-8
The rate at which energy decays in a damped String, Communications in Partial Differential Equations, vol.67, issue.1-2, pp.213-243, 1994. ,
DOI : 10.1080/03605309408821015
Exponential stabilization of well-posed systems by colocated feedback, SIAM Journal on Control and Optimization, vol.45, issue.1, pp.273-297, 2006. ,
DOI : 10.1137/040610489
An Introduction to Infinite Dimensional Linear Systems Theory, Texts in Applied Mathematics, vol.21, 1995. ,
DOI : 10.1007/978-1-4612-4224-6
Schur complements in C*-algebras, Mathematische Nachrichten, vol.302, issue.303, pp.808-814, 2005. ,
DOI : 10.1002/mana.200310273
Parameter identification for uncertain plants using H??? methods, Automatica, vol.31, issue.9, pp.1227-1250, 1995. ,
DOI : 10.1016/0005-1098(95)00073-6
Bayesian Filtering In Nonlinear Structural Systems With Applications To Structural Health Monitoring. Graduate College Dissertations and Theses. Paper 513, 2015. ,
Observers and initial state recovering for a class of hyperbolic systems via Lyapunov method, Automatica, vol.49, issue.7, pp.2250-2260, 2013. ,
DOI : 10.1016/j.automatica.2013.04.015
Recovering the observable part of the initial data of an infinite-dimensional linear system with skew-adjoint generator, Mathematics of Control, Signals, and Systems, vol.23, issue.1???2, pp.435-462, 2014. ,
DOI : 10.1007/s00498-014-0124-z
URL : https://hal.archives-ouvertes.fr/hal-00934239
Reconstructing initial data using observers: error analysis of the semi-discrete and fully discrete approximations, Numerische Mathematik, vol.47, issue.2, pp.307-343, 2012. ,
DOI : 10.1007/s00211-011-0408-x
URL : https://hal.archives-ouvertes.fr/hal-00730512
Une remarque sur la stabilisation de certains systèmes dudeuxì eme ordre en temps, Portugaliae Mathematica, vol.46, issue.3, pp.245-258, 1989. ,
Global Lipschitz stability in an inverse hyperbolic problem by interior observations, Inverse Problems, vol.17, issue.4, pp.717-728, 2001. ,
DOI : 10.1088/0266-5611/17/4/310
On Persistent Excitation for Linear Systems with Stochastic Coefficients, SIAM Journal on Control and Optimization, vol.40, issue.3, pp.882-897, 2001. ,
DOI : 10.1137/S0363012996300458
Locally Distributed Control and Damping for the Conservative Systems, SIAM Journal on Control and Optimization, vol.35, issue.5, pp.1574-1590, 1997. ,
DOI : 10.1137/S0363012995284928
Asymptotic behavior of the extended Kalman filter as a parameter estimator for linear systems, IEEE Transactions on Automatic Control, vol.24, issue.1, pp.36-50, 1979. ,
DOI : 10.1109/TAC.1979.1101943
An introduction to observers, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.596-602, 1971. ,
DOI : 10.1109/TAC.1971.1099826
Personalization of a cardiac electromechanical model using reduced order unscented Kalman filtering from regional volumes, Medical Image Analysis, vol.17, issue.7, pp.17816-829, 2013. ,
DOI : 10.1016/j.media.2013.04.012
URL : https://hal.archives-ouvertes.fr/hal-00819806
Impact induced composite delamination: state and parameter identification via joint and dual extended Kalman filters, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.50-52, pp.5242-5272, 2005. ,
DOI : 10.1016/j.cma.2005.01.007
Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems. ESAIM: Control, Optimisation and Calculus of Variations, pp.380-405, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00550104
Joint state and parameter estimation for distributed mechanical systems, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.6-8, pp.659-677, 2008. ,
DOI : 10.1016/j.cma.2007.08.021
URL : https://hal.archives-ouvertes.fr/hal-00175623
Solution of Equations in Euclidian and Banach Spaces, 1973. ,
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
DOI : 10.1007/978-1-4612-5561-1
Recovering the initial state of an infinite-dimensional system using observers, Automatica, vol.46, issue.10, pp.1616-1625, 2010. ,
DOI : 10.1016/j.automatica.2010.06.032
URL : https://hal.archives-ouvertes.fr/hal-00529834
Persistency of excitation in continuous-time systems, Systems & Control Letters, vol.9, issue.3, pp.225-233, 1987. ,
DOI : 10.1016/0167-6911(87)90044-2
