Journal articles
Stability of synchronization under stochastic perturbations in leaky integrate and fire neural networks of finite size.
Pierre Guiraud 1 Etienne Tanré 2
2 TOSCA - TO Simulate and CAlibrate stochastic models
CRISAM - Inria Sophia Antipolis - Méditerranée , IECL - Institut Élie Cartan de Lorraine : UMR7502
Abstract : In the present paper, we study the synchronization in a model of neural network which can be considered as a noisy version of the model of \citet{mirollo1990synchronization}, namely, fully-connected and totally excitatory integrate and fire neural network with Gaussian white noises. Using a large deviation principle, we prove the stability of the synchronized state under stochastic perturbations. Then, we give a lower bound on the probability of synchronization for networks which are not initially synchronized. This bound shows the robustness of the emergence of synchronization in presence of small stochastic perturbations.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01370609
Contributor : Etienne Tanré Connect in order to contact the contributor
Submitted on : Tuesday, September 27, 2016 - 11:57:33 AM
Last modification on : Friday, July 8, 2022 - 10:09:51 AM
Long-term archiving on: : Wednesday, December 28, 2016 - 1:14:03 PM
File
hal_synchro_pget.pdf
Identifiers
Citation
Pierre Guiraud, Etienne Tanré. Stability of synchronization under stochastic perturbations in leaky integrate and fire neural networks of finite size.. Discrete and Continuous Dynamical Systems - Series B, American Institute of Mathematical Sciences, 2019, 24 (9), pp.5183--5201. ⟨10.3934/dcdsb.2019056⟩. ⟨hal-01370609⟩
Share
Metrics
Record views
171
Files downloads
131
