Journal articles
Protein–protein docking by fast generalized Fourier transforms on 5D rotational manifolds
Abstract : Energy evaluation using fast Fourier transforms (FFTs) enables sampling billions of putative complex structures and hence revolutionized rigid protein–protein docking. However, in current methods, efficient acceleration is achieved only in either the translational or the rotational subspace. Developing an efficient and accurate docking method that expands FFT-based sampling to five rotational coordinates is an extensively studied but still unsolved problem. The algorithm presented here retains the accuracy of earlier methods but yields at least 10-fold speedup. The improvement is due to two innovations. First, the search space is treated as the product manifold SO(3)×(SO(3)∖S1), where SO(3) is the rotation group representing the space of the rotating ligand, and (SO(3)∖S1) is the space spanned by the two Euler angles that define the orientation of the vector from the center of the fixed receptor toward the center of the ligand. This representation enables the use of efficient FFT methods developed for SO(3). Second, we select the centers of highly populated clusters of docked structures, rather than the lowest energy conformations, as predictions of the complex, and hence there is no need for very high accuracy in energy evaluation. Therefore, it is sufficient to use a limited number of spherical basis functions in the Fourier space, which increases the efficiency of sampling while retaining the accuracy of docking results. A major advantage of the method is that, in contrast to classical approaches, increasing the number of correlation function terms is computationally inexpensive, which enables using complex energy functions for scoring.
Document type :
Journal articles
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-01371087
Contributor : David Ritchie Connect in order to contact the contributor
Submitted on : Monday, October 10, 2016 - 11:48:59 AM
Last modification on : Friday, July 8, 2022 - 10:09:17 AM
Long-term archiving on: : Saturday, February 4, 2017 - 12:39:48 AM
File
PNAS-2016-Padhorny-E4286-93.pd...
Identifiers
Collections
Citation
Dzmitry Padhorny, Andrey Kazennov, Brandon S Zerbe, Kathryn A Porter, Bing Xia, et al.. Protein–protein docking by fast generalized Fourier transforms on 5D rotational manifolds. Proceedings of the National Academy of Sciences of the United States of America, National Academy of Sciences, 2016, 113 (30), pp.E4286-E4293. ⟨10.1073/pnas.1603929113⟩. ⟨hal-01371087⟩
Share
Metrics
Record views
178
Files downloads
139
