Almost Global Attractivity of a Synchronous Generator Connected to an Infinite Bus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of deriving verifiable conditions for stability of the equilibria of a realistic model of a synchronous generator with constant field current connected to an infinite bus is studied in the paper. Necessary and sufficient conditions for existence and uniqueness of equilibrium points are provided. Furthermore, sufficient conditions for almost global attractivity are given. To carry out this analysis a new Lyapunov–like function is proposed to establish convergence of bounded trajectories, while the latter is proven using the powerful theoretical framework of cell structures pioneered by Leonov and Noldus.
CDC16_0034_Barabanov.pdf (247.72 Ko) Télécharger le fichier
hal-01371271 , version 1 (25-09-2016)
Nikita Barabanov, Johannes Schiffer, Romeo Ortega, Denis Efimov. Almost Global Attractivity of a Synchronous Generator Connected to an Infinite Bus. 55th IEEE Conference on Decision and Control (CDC 2016), Dec 2016, Las Vegas, United States. ⟨10.1109/cdc.2016.7798895⟩. ⟨hal-01371271⟩
344 Consultations
225 Téléchargements
