Power system dynamics: stability and control, J.Wiley & Sons, 2008. ,
Definition and classification of power system stability IEEE/CIGRE joint task force on stability terms and definitions, IEEE Transactions on Power Systems, vol.19, issue.3, pp.1387-1401, 1923. ,
Fast time-varying phasor analysis in the balanced three-phase large electric power system, IEEE Transactions on Automatic Control, vol.40, issue.11, pp.1975-1982, 1995. ,
DOI : 10.1109/9.471228
Power system dynamics and stability, 1998. ,
Power system stability and control, 1994. ,
A port-Hamiltonian approach to power network modeling and analysis, European Journal of Control, vol.19, issue.6, pp.477-485, 2013. ,
DOI : 10.1016/j.ejcon.2013.09.002
Compositional Transient Stability Analysis of Multimachine Power Networks, IEEE Transactions on Control of Network Systems, vol.1, issue.1, pp.4-14, 2014. ,
DOI : 10.1109/TCNS.2014.2304868
Uses and abuses of the swing equation model, 2015 54th IEEE Conference on Decision and Control (CDC), pp.6662-6667, 2015. ,
DOI : 10.1109/CDC.2015.7403268
The path of the smart grid, IEEE Power and Energy Magazine, vol.8, issue.1, pp.18-28, 2010. ,
DOI : 10.1109/MPE.2009.934876
Pushing the Limits: Europe's New Grid: Innovative Tools to Combat Transmission Bottlenecks and Reduced Inertia, IEEE Power and Energy Magazine, vol.13, issue.1, pp.60-74, 2015. ,
DOI : 10.1109/MPE.2014.2363534
Almost global asymptotic stability of a constant field current synchronous machine connected to an infinite bus, 53rd IEEE Conference on Decision and Control, 2014. ,
DOI : 10.1109/CDC.2014.7039895
On the boundedness of the trajectories of phase systems, Siberian Mathematical Journal, vol.8, issue.No. 6, pp.491-495, 1974. ,
DOI : 10.1007/BF00969820
Stability of nonlinear systems with nonunique equilibrium position, Moscow Izdatel Nauka, vol.1, 1978. ,
Stability of stationary sets in control systems with discontinuous nonlinearities. World Sc, 2004. ,
New direct lyapunov-type method for studying synchronization problems, Automatica, vol.13, issue.2, pp.139-151, 1977. ,
DOI : 10.1016/0005-1098(77)90038-3
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Power system analysis, 1994. ,
Synchronverters: Inverters That Mimic Synchronous Generators, IEEE Transactions on Industrial Electronics, vol.58, issue.4, pp.1259-1267, 2011. ,
DOI : 10.1109/TIE.2010.2048839
A survey on modeling of microgrids???From fundamental physics to phasors and voltage sources, Automatica, vol.74, 2016. ,
DOI : 10.1016/j.automatica.2016.07.036
Phase synchronisation. theory and applications, Nonlinear Systems: Frequency and Matrix Inequalities, 2008. ,
