Observer-based Control for Linear Sampled-Data Systems: An Impulsive System Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the sampled-data control problem based on state estimation for linear sampled-data systems. An impulsive system approach is proposed based on a vector Lyapunov function method. Observer-based control design conditions are expressed in terms of LMIs. Some examples illustrate the feasibility of the proposed approach.
CDC16_0102_Hector.pdf (1.6 Mo) Télécharger le fichier
hal-01371272 , version 1 (25-09-2016)
  • HAL Id : hal-01371272 , version 1
Héctor Ríos, Laurentiu Hetel, Denis Efimov. Observer-based Control for Linear Sampled-Data Systems: An Impulsive System Approach. Proc. 55th IEEE Conference on Decision and Control (CDC), Dec 2016, Las Vegas, United States. ⟨hal-01371272⟩
198 Consultations
271 Téléchargements
