Enabling a lightweight Edge Gateway-as-a-Service for the Internet of Things - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Roberto Morabito
  • Fonction : Auteur
  • PersonId : 967989
Riccardo Petrolo
  • Fonction : Auteur
  • PersonId : 953963
Valeria Loscrì
  • Fonction : Auteur
  • PersonId : 1084587
Since its introduction, the Internet of Things (IoT) has changed several aspects of our lives, leading to the commercialization of different heterogeneous devices. In order to bridge the gap among these heterogeneous devices, in some of the most common IoT use cases -e.g., smart home, smart buildings, etc.-the presence of a gateway as an enabler of interoperability is required. In this paper, we introduce the concept of a Gateway-as- a-Service (GaaS), a lightweight device that can be shared between different users thanks to the use of virtualization techniques. Performance has been evaluated on real hardware and results demonstrate the lightweight characteristics of the proposal.
main_personalCopy.pdf (1.62 Mo) Télécharger le fichier
hal-01371423 , version 1 (16-11-2016)
  • HAL Id : hal-01371423 , version 1
Roberto Morabito, Riccardo Petrolo, Valeria Loscrì, Nathalie Mitton. Enabling a lightweight Edge Gateway-as-a-Service for the Internet of Things. NOF 2016 - 7th International Conference on Network of the Future, Nov 2016, Buzios, Rio de Janeiro, Brazil. ⟨hal-01371423⟩
Collections
INRIA INRIA2
278 Consultations
589 Téléchargements
