Finite-time parameter estimation in adaptive control of nonlinear systems, IEEE Transactions on Automatic Control, vol.53, issue.3, 2008. ,
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals, and Systems, vol.17, issue.2, pp.101-127, 2005. ,
DOI : 10.1007/s00498-005-0151-x
On-line parameter estimation for a class of time-varying continuous systems with bounded disturbances, International Journal of Adaptive Control and Signal Processing, vol.43, issue.10, pp.18-32, 2011. ,
DOI : 10.1002/acs.1188
Observation and identification of mechanical systems via second order sliding modes, International Journal of Control, vol.5, issue.10, pp.79-1251, 2006. ,
DOI : 10.1080/00207170600801635
Short-time stability in linear timevarying systems, 1961. ,
Finitetime stability for time-varying nonlinear dynamical systems, Proc. ACC, pp.4135-4139, 2008. ,
Parameter identification, experimental design and model falsification for biological network models using semidefinite programming, IET Systems Biology, vol.4, issue.2, pp.119-130, 2010. ,
DOI : 10.1049/iet-syb.2009.0030
System identification in communication with chaotic systems, IEEE Transactions on Circuits and Systems -I: Fundamental Theory and Applications, pp.47-800, 2000. ,
DOI : 10.1109/81.852932
Robust Adaptive Control, 1996. ,
DOI : 10.1201/b10384-41
URL : https://hal.archives-ouvertes.fr/hal-01394197
Identification of Dynamic Systems, An Introduction with Applications, 2011. ,
On stability of motion over a finite interval of time, Journal of Applied Math. and Mechanics (PMM), vol.17, pp.529-540, 1953. ,
Nonlinear Systems, 2002. ,
The problem of stability in a finite interval of time, Journal of Applied Math. and Mechanics (PMM), vol.18, pp.75-94, 1954. ,
System Identification: Theory for the User, Prentice Hall Information and System Sciences Series, 1999. ,
Strict Lyapunov Functions for the Super-Twisting Algorithm, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1035-1040, 2012. ,
DOI : 10.1109/TAC.2012.2186179
A New Recursive Finite-Time Convergent Parameter Estimation Algorithm, Proccedings of the 18th IFAC World Congress, pp.3439-3444, 2011. ,
DOI : 10.3182/20110828-6-IT-1002.03387
Second order sliding mode observer for estimation of velocities, wheel sleep, radius and stiffness, Proceedings of the 2006 American Control Conference, pp.3316-3321, 2006. ,
Averaging Results and the Study of Uniform Asymptotic Stability of Homogeneous Differential Equations That Are Not Fast Time-Varying, SIAM Journal on Control and Optimization, vol.37, issue.4, pp.997-1010, 1999. ,
DOI : 10.1137/S0363012997323862
Stability notions and Lyapunov functions for sliding mode control systems, Journal of the Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014. ,
DOI : 10.1016/j.jfranklin.2014.01.002
URL : https://hal.archives-ouvertes.fr/hal-00942319
Homogeneity Based Uniform Stability Analysis for Time-Varying Systems, IEEE Transactions on Automatic Control, vol.61, issue.3, pp.61-725, 2016. ,
DOI : 10.1109/TAC.2015.2446371
Homogeneous Time-Varying Systems: Robustness Analysis, IEEE Transactions on Automatic Control, vol.61, issue.12, 2016. ,
DOI : 10.1109/TAC.2016.2540806
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
System Identification, Journal of Dynamic Systems, Measurement, and Control, vol.115, issue.4, 1989. ,
DOI : 10.1115/1.2899207
Identification of mechanical parameters of hard-coating materials with strain-dependence, Journal of Mechanical Science and Technology, vol.21, issue.1, pp.81-92, 2014. ,
DOI : 10.1007/s12206-013-0939-4
ON THE STABILITY OF SYSTEMS DEFINED OVER A FINITE TIME INTERVAL, Proc. of the National Academy of Sciences, pp.440-448, 1965. ,
DOI : 10.1073/pnas.54.1.44
A VSS identification scheme for time-varying parameters, Automatica, vol.39, issue.4, pp.727-734, 2003. ,
DOI : 10.1016/S0005-1098(02)00303-5
Distributed parameter system identification and its application to geophysical parameter identification, Proceedings of 1994 IEEE International Conference on Industrial Technology, ICIT '94, pp.799-802, 1994. ,
DOI : 10.1109/ICIT.1994.467029
On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica, vol.1, pp.80-88, 1958. ,
