Upwind methods for hyperbolic conservation laws with source terms, Computers & Fluids, vol.23, issue.8, pp.1049-1071, 1994. ,
DOI : 10.1016/0045-7930(94)90004-3
Flux Difference Splitting and the Balancing of Source Terms and Flux Gradients, Journal of Computational Physics, vol.165, issue.1, pp.89-125, 2000. ,
DOI : 10.1006/jcph.2000.6603
Godunov-type methods for free surface shallow water flows: a review, J.Hydraul.Res, vol.45, p.746, 2007. ,
Central schemes for balance laws, Hyperbolic Problems: Theory, Numerics, Applications, pp.821-829, 2001. ,
Central-Upwind Schemes for the Saint-Venant System, ESAIM: M2AN, pp.397-425, 2002. ,
DOI : 10.1051/m2an:2002019
A Second-Order Well-Balanced Positivity Preserving Central-Upwind Scheme for the Saint-Venant System, Communications in Mathematical Sciences, vol.5, issue.1, pp.133-160, 2007. ,
DOI : 10.4310/CMS.2007.v5.n1.a6
Mathematical balancing of flux gradient and source terms prior to using Roe???s approximate Riemann solver, Journal of Computational Physics, vol.192, issue.2, pp.422-451, 2003. ,
DOI : 10.1016/j.jcp.2003.07.020
Adaptive quadtree simulation of shallow flows with wet???dry fronts over complex topography, Computers & Fluids, vol.38, issue.2, pp.221-234, 2009. ,
DOI : 10.1016/j.compfluid.2008.02.008
Numerical resolution of well-balanced shallow water equations with complex source terms, Advances in Water Resources, vol.32, issue.6, pp.873-884, 2009. ,
DOI : 10.1016/j.advwatres.2009.02.010
URL : https://hal.archives-ouvertes.fr/hal-00799080
Unsteady free surface flow simulation over complex topography with a multidimensional upwind technique, Journal of Computational Physics, vol.186, issue.2, pp.503-526, 2003. ,
DOI : 10.1016/S0021-9991(03)00072-X
Application of conservative residual distribution schemes to the solution of the shallow water equations on unstructured meshes, Journal of Computational Physics, vol.222, issue.1, pp.287-331, 2007. ,
DOI : 10.1016/j.jcp.2006.06.024
URL : https://hal.archives-ouvertes.fr/inria-00402649
Stabilized residual distribution for shallow water simulations, Journal of Computational Physics, vol.228, issue.4, pp.1071-111, 2009. ,
DOI : 10.1016/j.jcp.2008.10.020
URL : https://hal.archives-ouvertes.fr/inria-00538892
On the C-property and Generalized C-property of??Residual Distribution for the Shallow Water Equations, Journal of Scientific Computing, vol.228, issue.1, pp.304-318, 2011. ,
DOI : 10.1007/s10915-010-9369-y
URL : https://hal.archives-ouvertes.fr/inria-00538844
An explicit residual based approach for shallow water flows, Journal of Computational Physics, vol.280, pp.306-344, 2015. ,
DOI : 10.1016/j.jcp.2014.09.027
URL : https://hal.archives-ouvertes.fr/hal-01087940
3D transient fixed point mesh adaptation for time-dependent problems: Application to CFD simulations, Journal of Computational Physics, vol.222, issue.2, pp.592-623, 2007. ,
DOI : 10.1016/j.jcp.2006.08.012
Arbitrary lagrangian eulerian formulation for two-dimensional flows using dynamic meshes with edge swapping, J. Comp. Phys, vol.230, pp.7706-7722, 2011. ,
Adaptive Mesh Methods for One- and Two-Dimensional Hyperbolic Conservation Laws, SIAM Journal on Numerical Analysis, vol.41, issue.2, pp.487-515, 2003. ,
DOI : 10.1137/S003614290138437X
Adaptivity with moving grids, Acta Numerica, vol.20, pp.1-131, 2009. ,
DOI : 10.1016/j.jcp.2007.01.019
Fundamental concepts and approaches, Hanbook of Grid Generation, p.10, 1999. ,
Numerical solution of the quasilinear poisson equation in a nonuniform triangle mesh, Journal of Computational Physics, vol.1, issue.2, pp.149-172, 1967. ,
DOI : 10.1016/0021-9991(66)90001-5
An Efficient Dynamically Adaptive Mesh for Potentially Singular Solutions, Journal of Computational Physics, vol.172, issue.2, pp.609-639, 2008. ,
DOI : 10.1006/jcph.2001.6844
Monge???Amp??re based moving mesh methods for numerical weather prediction, with applications to the Eady problem, Journal of Computational Physics, vol.236, 2012. ,
DOI : 10.1016/j.jcp.2012.11.014
Anisotropic mesh adaptation and movement. Workshop on Adaptive Method, Theory and Application, 2005. ,
Adaptive zoning for singular problems in two dimensions, Journal of Computational Physics, vol.46, issue.3, p.342, 1982. ,
DOI : 10.1016/0021-9991(82)90020-1
A High-Order Moving Mesh Kinetic Scheme Based on WENO Reconstruction for Compressible Flows on Unstructured Meshes, Journal of Scientific Computing, vol.178, issue.3, pp.278-299, 2013. ,
DOI : 10.1007/s10915-013-9705-0
Unsteady flow simulation using a zonal multigrid approach with moving boundaries, pp.94-0057, 1994. ,
Geometric conservation laws for flow problems with moving boundaries and deformable meshes, and their impact on aeroelastic computations, Computer Methods in Applied Mechanics and Engineering, vol.134, issue.1-2, pp.71-90, 1996. ,
DOI : 10.1016/0045-7825(96)01028-6
An adaptive moving finite volume scheme for modeling flood inundation over dry and complex topography, Water Resources Research, vol.130, issue.1, pp.1914-1928, 2013. ,
DOI : 10.1002/wrcr.20179
A well-balanced stable generalized Riemann problem scheme for shallow water equations using adaptive moving unstructured triangular meshes, International Journal for Numerical Methods in Fluids, vol.32, issue.6, pp.266-283, 2013. ,
DOI : 10.1002/fld.3800
Arbitrary lagrangian eulerian finite element methods. In Computational Methods for Transient Analysis, chapter 10, 1983. ,
An unstructured node-centered finite volume scheme for shallow water flows with wet/dry fronts over complex topography, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.47-48, pp.3723-3750, 2009. ,
DOI : 10.1016/j.cma.2009.08.006
A Fast and Stable Well-Balanced Scheme with Hydrostatic Reconstruction for Shallow Water Flows, SIAM Journal on Scientific Computing, vol.25, issue.6, pp.2050-2065, 2004. ,
DOI : 10.1137/S1064827503431090
An ALE Formulation for Explicit Runge???Kutta Residual Distribution, Journal of Scientific Computing, vol.215, issue.1, pp.1467-1482, 2014. ,
DOI : 10.1007/s10915-014-9910-5
URL : https://hal.archives-ouvertes.fr/hal-01087947
An Interpolation Free Two-Dimensional Conservative ALE scheme over Adaptive Unstructured Grids for Rotorcraf Aerodynamics ,
Performance and Comparison of Cell-Centered and??Node-Centered Unstructured Finite Volume Discretizations for??Shallow Water Free Surface Flows, Archives of Computational Methods in Engineering, vol.38, issue.7, pp.57-118, 2011. ,
DOI : 10.1007/s11831-011-9057-6
High-resolution methods. In Finite Volume Methods for Hyperbolic problems, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01342271
A numerical model for the flooding and drying of irregular domains, International Journal for Numerical Methods in Fluids, vol.38, issue.5, pp.247-275, 2002. ,
DOI : 10.1002/fld.285
Zero mass error using unsteady wetting???drying conditions in shallow flows over dry irregular topography, International Journal for Numerical Methods in Fluids, vol.45, issue.10, pp.1047-1082, 2004. ,
DOI : 10.1002/fld.729
A robust high-resolution finite volume scheme for the simulation of long waves over complex domains, International Journal for Numerical Methods in Fluids, vol.29, issue.4, pp.419-452, 2008. ,
DOI : 10.1002/fld.1537
Explicit Runge???Kutta residual distribution schemes for time dependent problems: Second order case, Journal of Computational Physics, vol.229, issue.16, pp.5653-5691, 2010. ,
DOI : 10.1016/j.jcp.2010.04.002
URL : https://hal.archives-ouvertes.fr/inria-00406958
Streamline upwind Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Comp. Meth. Appl. Mech. Engrg, vol.32, pp.199-259, 1982. ,
Stabilized Methods for Compressible Flows, Journal of Scientific Computing, vol.190, issue.10, pp.343-368, 2010. ,
DOI : 10.1007/s10915-008-9233-5
Multidimensional upwinding for grid adaptation. Numerical Methods for Wave Propagation, pp.33-54, 1998. ,
Second-Order Accurate Godunov Scheme for??Multicomponent Flows on Moving Triangular Meshes, Journal of Scientific Computing, vol.1, issue.1, pp.64-86, 2008. ,
DOI : 10.1007/s10915-007-9162-8
A moving mesh finite element algorithm for signular problems in two and three space dimensions ,
On the use of moving mesh methods to solve pdes, Adaptive Computations: Theory and Algorithms, pp.242-278, 2007. ,
Non-oscillatory relaxation methods for the shallow-water equations in one and two space dimensions, International Journal for Numerical Methods in Fluids, vol.46, issue.5, pp.457-484, 2004. ,
DOI : 10.1002/fld.766
Laboratory experiments of tsunami runup on a circular island, Pure and Applied Geophysics PAGEOPH, vol.74, issue.33, pp.569-593, 1995. ,
DOI : 10.1007/BF00874384
Advanced Numerical Models for Simulating Tsunami Waves and Runup, of Advances in Coastal and Ocean Engineering. World Scientific, 2008. ,
DOI : 10.1142/6226
Tsunami runup onto a complex three-dimensional beach; monai valley ,
EXPERIMENTAL STUDY OF SOLITARY WAVE EVOLUTION OVER A 3D SHALLOW SHELF, Proc. 32th Conf. Coast. Engng, p.813, 2010. ,
DOI : 10.9753/icce.v32.currents.1
Boussinesq-type model for energetic breaking waves in fringing reef environments, Coastal Engineering, vol.70, pp.1-20, 2012. ,
DOI : 10.1016/j.coastaleng.2012.06.001
Numerical treatment of wave breaking on unstructured finite volume approximations for extended Boussinesq-type equations, Journal of Computational Physics, vol.271, pp.281-305, 2014. ,
DOI : 10.1016/j.jcp.2014.01.030
A flexible genuinely nonlinear approach for nonlinear wave propagation, breaking and run-up, Journal of Computational Physics, vol.310, pp.381-417, 2016. ,
DOI : 10.1016/j.jcp.2016.01.027
Automatic mesh update with the solid-extension mesh moving technique, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.21-22 ,
DOI : 10.1016/j.cma.2003.12.046
