A Bayesian and Smart Gateway Based Communication For Noisy IoT Scenario - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays, Internet of Things (IoT) coupled with cloud computing begins to take an important place in economic systems and in society daily life. It has got a large success in several application areas, ranging from smart city applications to smart grids. One major challenge that should be addressed is the huge amount of data generated by the sensing devices, which make the control of sending useless data very important. To face this challenge, we present a Bayesian Inference Approach (BIA), which allows avoiding the transmission of high spatio-temporal correlated data. In this paper, BIA is based on a hierarchical architecture with simple nodes, smart gateways and data centers. Belief Propagation algorithm has been chosen for performing an approximate inference on our model in order to reconstruct the missing sensing data. BIA is evaluated based on the data collected from real sensors and according to different scenarios. The results show that our proposed approach reduces drastically the number of transmitted data and the energy consumption, while maintaining an acceptable level of data prediction accuracy.
Bp-based-paper_v3.pdf (435.8 Ko) Télécharger le fichier
hal-01372546 , version 1 (30-01-2017)
  • HAL Id : hal-01372546 , version 1
Cristanel Razafimandimby, Valeria Loscrì, Anna Maria Vegni, Alessandro Neri. A Bayesian and Smart Gateway Based Communication For Noisy IoT Scenario . ICNC 2017 - International Conference on Computing, Networking and Communications, Jan 2017, Silicon Valley, United States. ⟨hal-01372546⟩
Collections
INRIA INRIA2
200 Consultations
409 Téléchargements
