Smooth interpolation of curve networks with surface normals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent surface acquisition technologies based on microsensors produce three-space tangential curve data which can be transformed into a network of space curves with surface normals. This paper addresses the problem of surfacing an arbitrary closed 3D curve network with given surface normals. Thanks to the normal vector input, the patch finding problem can be solved unambiguously and an initial piecewise smooth triangle mesh is computed. The input normals are propagated throughout the mesh and used to compute mean curvature vectors. We then introduce a new variational optimization method in which the standard bi-Laplacian is penalized by a term based on the mean curvature vectors. The intuition behind this original approach is to guide the standard Laplacian-based variational methods by the curvature information extracted from the input normals. The normal input increases shape fidelity and allows to achieve globally smooth and visually pleasing shapes.
paper.bib (1.35 Ko) Télécharger le fichier
Format : Autre
hal-01372958 , version 1 (27-09-2016)
  • HAL Id : hal-01372958 , version 1
Tibor Stanko, Stefanie Hahmann, Georges-Pierre Bonneau, Nathalie Saguin-Sprynski. Smooth interpolation of curve networks with surface normals. GTMG 2016 — Actes des Journées du Groupe de Travail en Modélisation Géométrique, Mar 2016, Dijon, France, France. pp.30-34. ⟨hal-01372958⟩
221 Consultations
2 Téléchargements
