Flow Research SXP Agile Methodology for FOSS Projects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper aims to explain a procedure that takes into account the different research processes carried out in developing an open-source, allowing control and management. This study is the SXP methodology applied in this type of project was carried out, allowing the validity of the basis of this research.
978-3-642-55128-4_28_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01373100 , version 1 (28-09-2016)
Paternité
Gladys Marsi Peñalver Romero, Lisandra Isabel Leyva Samada, Abel Meneses Abad. Flow Research SXP Agile Methodology for FOSS Projects. 10th IFIP International Conference on Open Source Systems (OSS), May 2014, San José, Costa Rica. pp.195-198, ⟨10.1007/978-3-642-55128-4_28⟩. ⟨hal-01373100⟩
50 Consultations
88 Téléchargements
