Sobolev spaces, 2003. ,
Optimization algorithm for reconstructing interface changes of a conductivity inclusion from modal measurements, Mathematics of Computation, vol.79, issue.271, pp.1757-1777, 2010. ,
DOI : 10.1090/S0025-5718-10-02344-6
Reconstruction of small interface changes of an inclusion from modal measurements II: The elastic case, Journal de Math??matiques Pures et Appliqu??es, vol.94, issue.3, pp.322-339, 2010. ,
DOI : 10.1016/j.matpur.2010.02.001
Multistatic Imaging of Extended Targets, SIAM Journal on Imaging Sciences, vol.5, issue.2, pp.564-600, 2012. ,
DOI : 10.1137/10080631X
URL : https://hal.archives-ouvertes.fr/hal-00708144
Effective impedance boundary conditions for an inhomogeneous thin layer on a curved metallic surface, IEEE Transactions on Antennas and Propagation, vol.46, issue.5, pp.710-716, 1998. ,
DOI : 10.1109/8.668915
A MUSIC-type algorithm for detecting internal corrosion from electrostatic boundary measurements, Numerische Mathematik, vol.14, issue.4, pp.501-528, 2008. ,
DOI : 10.1007/s00211-007-0130-x
URL : https://hal.archives-ouvertes.fr/hal-00125787
Generalized impedance boundary conditions for thin dielectric coatings with variable thickness, Wave Motion, vol.48, issue.7, pp.681-700, 2011. ,
DOI : 10.1016/j.wavemoti.2011.06.002
Application of the linear sampling method to identify cracks with impedance boundary conditions, Inverse Problems in Science and Engineering, vol.93, issue.2, pp.210-234, 2013. ,
DOI : 10.1016/j.jcp.2011.01.038
URL : https://hal.archives-ouvertes.fr/hal-00743816
The factorization method for inverse acoustic scattering in a layered medium, Inverse Problems, vol.29, issue.4, 2013. ,
DOI : 10.1088/0266-5611/29/4/045010
The factorization method applied to cracks with impedance boundary conditions, Inverse Problems and Imaging, vol.7, issue.4, pp.1123-1138, 2013. ,
DOI : 10.3934/ipi.2013.7.1123
URL : https://hal.archives-ouvertes.fr/hal-00768729
Acoustic Attenuation for Ultrasonic NDI Detection of Delaminations on Composite Laminates, Journal of Reinforced Plastics and Composites, vol.20, issue.1, pp.176-187, 2001. ,
DOI : 10.1177/073168401772678409
The linear sampling method for cracks, Inverse Problems, vol.19, issue.2, pp.279-295, 2003. ,
DOI : 10.1088/0266-5611/19/2/303
A Qualitative Approach to Inverse Scattering Theory, 2014. ,
DOI : 10.1007/978-1-4614-8827-9
Transmission eigenvalues and inverse scattering theory ,
DOI : 10.1137/1.9781611974461
URL : https://hal.archives-ouvertes.fr/hal-01374893
The factorization method for a defective region in an anisotropic material, Inverse Problems, vol.31, issue.2, 2015. ,
DOI : 10.1088/0266-5611/31/2/025002
Analysis of the factorization method for a general class of boundary conditions, Journal of Inverse and Ill-posed Problems, vol.22, issue.5, pp.643-670, 2014. ,
DOI : 10.1515/jip-2013-0013
URL : https://hal.archives-ouvertes.fr/hal-00783288
Inverse Acoustic and Electromagnetic Scattering Theory, 2013. ,
Asymptotic Methods in Inverse Scattering for Inhomogeneous Media, 2016. ,
Modeles et asymptotiques des interfaces fines et periodiques en electromagnetisme, 2010. ,
URL : https://hal.archives-ouvertes.fr/tel-00650354
Approximate models for wave propagation across thin periodic interfaces, Journal de Math??matiques Pures et Appliqu??es, vol.98, issue.1, pp.28-71, 2012. ,
DOI : 10.1016/j.matpur.2012.01.003
URL : https://hal.archives-ouvertes.fr/hal-00741614
Efficient detection of delamination in multilayered structures using ultrasonic guided wave EMATs, NDT & E International, vol.43, issue.4, pp.316-322, 2010. ,
DOI : 10.1016/j.ndteint.2010.03.004
Determining the shape of defects in non-absorbing inhomogeneous media from far-field measurements, Inverse Problems, vol.28, issue.5, p.2012 ,
DOI : 10.1088/0266-5611/28/5/055003
URL : https://hal.archives-ouvertes.fr/hal-00805796
GENERALIZED IMPEDANCE BOUNDARY CONDITIONS FOR SCATTERING BY STRONGLY ABSORBING OBSTACLES: THE SCALAR CASE, Mathematical Models and Methods in Applied Sciences, vol.15, issue.08, pp.1273-1300, 2005. ,
DOI : 10.1142/S021820250500073X
URL : https://hal.archives-ouvertes.fr/hal-00743895
The Analysis of Linear Partial Differential Operators III, 1985. ,
A linear sampling method for inverse scattering from an open arc, Inverse Problems, vol.16, issue.1, pp.89-105, 2000. ,
DOI : 10.1088/0266-5611/16/1/308
Strongly elliptic systems and boundary integral equations Reconstruction of the electromagnetic field in layered media using the concept of approximate transmission conditions, IEEE Transactions on Antennas and Propagation, vol.59, pp.2964-2972, 2000. ,
Detection of Delamination in Concrete Bridge Decks by Joint Amplitude and Phase Analysis of Ultrasonic Array Measurements, Journal of Bridge Engineering, vol.19, issue.3, 2014. ,
DOI : 10.1061/(ASCE)BE.1943-5592.0000513
Delamination Detection in Laminated Composites Using Lamb Waves, Recent Advances in Composite Materials: In Honor of S.A. Paipetis, pp.109-126 ,
DOI : 10.1007/978-94-017-2852-2_10
The Factorization Method for Reconstructing a Penetrable Obstacle with Unknown Buried Objects, SIAM Journal on Applied Mathematics, vol.73, issue.2, pp.617-635, 2013. ,
DOI : 10.1137/120883724
The Identification of Thin Dielectric Objects from Far Field or Near Field Scattering Data, SIAM Journal on Applied Mathematics, vol.69, issue.4, pp.1024-1042, 2009. ,
DOI : 10.1137/070711542
