Journal articles
Assume-admissible synthesis
Abstract : In this paper, we introduce a novel rule for synthesis of reactive systems, applicable to systems made of n components which have each their own objectives. This rule is based on the notion of admissible strategies. We compare this rule with previous rules defined in the literature, and show that contrary to the previous proposals, it defines sets of solutions which are rectangular. This property leads to solutions which are robust and resilient, and allows one to synthesize strategies separately for each agent. We provide algorithms with optimal complexity and also an abstraction framework compatible with the new rule.
Document type :
Journal articles
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01373538
Contributor : Ocan Sankur Connect in order to contact the contributor
Submitted on : Wednesday, September 28, 2016 - 10:26:27 PM
Last modification on : Wednesday, February 2, 2022 - 3:53:44 PM
File
aa.pdf
Identifiers
Citation
Romain Brenguier, Jean-François Raskin, Ocan Sankur. Assume-admissible synthesis. Acta Informatica, Springer Verlag, 2016, ⟨10.1007/s00236-016-0273-2⟩. ⟨hal-01373538⟩
Share
Metrics
Record views
236
Files downloads
127
