Knapsack problem for automaton groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
The knapsack problem is a classic optimisation problem that has been recently extended in the setting of groups. Its study reveals to be interesting since it provides many different behaviours, depending on the considered class of groups. In this paper we deal with groups generated by Mealy automata—a class that is often used to study group-theoretical conjectures—and prove that the knapsack problem is undecidable for this class. In a second time, we construct a graph that, if finite, provides a solution to the knapsack problem. We deduce that the knapsack problem is decidable for the so-called bounded automaton groups, a class where the order and conjugacy problems are already known to be decidable.
knapsack_arxiv.pdf (215.66 Ko) Télécharger le fichier
hal-01373796 , version 1 (29-09-2016)
Thibault Godin. Knapsack problem for automaton groups. 2016. ⟨hal-01373796⟩
129 Consultations
180 Téléchargements
