New N^C^N-coordinated Pd(II) and Pt(II) complexes of a tridentate N-heterocyclic carbene ligand featuring a 6-membered central ring: synthesis, structures and luminescence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Dalton Transactions Année : 2016
We describe Pd(II) and Pt(II) complexes of an N^C^N-coordinating pincer-like ligand featuring two lateral pyridine rings and a 6-membered carbene core. Their crystal structures display 1-dimensional chains with short π–π and M(II)⋯M(II) interactions. Such interactions also impact on the photophysical properties, with the Pt(II) complex being luminescent in the solid state at room temperature.
Moussa_2016_New.pdf (766.65 Ko) Télécharger le fichier
hal-01373839 , version 1 (29-09-2016)
Jamal Moussa, Kamel Haddouche, Lise-Marie Chamoreau, Hani Amouri, J. A. Gareth Williams. New N^C^N-coordinated Pd(II) and Pt(II) complexes of a tridentate N-heterocyclic carbene ligand featuring a 6-membered central ring: synthesis, structures and luminescence . Dalton Transactions, 2016, 45 (32), pp.12644-12648 ⟨10.1039/C6DT02415G⟩. ⟨hal-01373839⟩
66 Consultations
221 Téléchargements
