SPREAD: A Balancing Constraint Based on Statistics, CP 2005, pp.460-474, 2005. ,
DOI : 10.1007/11564751_35
Bound-Consistent Deviation Constraint, CP 2007, pp.620-634, 2007. ,
DOI : 10.1007/978-3-540-74970-7_44
A ??(n) Bound-Consistency Algorithm for the Increasing Sum Constraint, CP 2011, pp.721-728, 2011. ,
DOI : 10.1007/978-3-642-23786-7_54
URL : https://hal.archives-ouvertes.fr/hal-00753385
Improved Bound Computation in Presence of Several Clique Constraints, CP 2004, pp.527-541, 2004. ,
DOI : 10.1007/978-3-540-30201-8_39
The Objective Sum Constraint, CPAIOR 2011, pp.190-195, 2011. ,
DOI : 10.1007/978-3-642-21311-3_18
When do bounds and domain propagation lead to the same search space?, ACM Transactions on Programming Languages and Systems, vol.27, issue.3, pp.388-425, 2005. ,
DOI : 10.1145/1065887.1065889
Finite Domain Bounds Consistency Revisited, Advances in Artificial Intelligence LNCS, vol.4304, pp.49-58, 2006. ,
DOI : 10.1007/11941439_9
GAC for a linear inequality and an Atleast constraint with an application to learning simple polynomials, SoCS, vol.2013, pp.149-157, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00874297
Bounds consistency techniques for long Linear constraints, Proceedings of TRICS 2002, the workshop on Techniques foR Implementing Constraint programming Systems, pp.39-46, 2002. ,
Bound-consistent Spread constraint, application to load balancing in nurse-to-patient assignments, EURO Journal on Computational Optimization, pp.1-24, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01345924
Recent Developments in Discrete Convex Analysis, Research Trends in Combinatorial Optimization, pp.219-260, 2009. ,
DOI : 10.1007/978-3-540-76796-1_11
Submodular Functions and Optimization, Annals of Discrete Mathematics, 2005. ,
Introducing global constraints in CHIP, Mathematical and Computer Modelling, vol.20, issue.12, pp.97-123, 1994. ,
DOI : 10.1016/0895-7177(94)90127-9
URL : https://hal.archives-ouvertes.fr/hal-00442810
Among, Common and Disjoint constraints, CSCLP 2005; Revised Selected and Invited Papers, pp.28-43, 2006. ,
Solving balancing and bin-packing problems with constraint programming, 2009. ,
The recomputation manifesto, CoRR abs/1304 ,
A generalized arc-consistency algorithm for a class of counting constraints, pp.643-648, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00754017
The SeqBin Constraint Revisited, CP 2012, pp.332-347, 2012. ,
DOI : 10.1007/978-3-642-33558-7_26
Cost-based arc consistency for global cardinality constraints, Constraints, vol.7, pp.3-4, 2002. ,
Constraint satisfaction over connected row-convex constraints, Artificial Intelligence, vol.109, issue.1-2, pp.1-2, 1999. ,
DOI : 10.1016/S0004-3702(99)00012-0
URL : http://doi.org/10.1016/s0004-3702(99)00012-0
Properties of tree convex constraints, Artificial Intelligence, vol.172, issue.12-13, pp.12-13, 2008. ,
DOI : 10.1016/j.artint.2008.05.001
A dynamic programming approach for consistency and propagation for knapsack constraints, Annals of Operations Research, vol.118, pp.1-4, 2003. ,
Achieving Domain Consistency and Counting Solutions for Dispersion Constraints, INFORMS Journal on Computing, vol.27, issue.4, pp.690-703, 2015. ,
DOI : 10.1287/ijoc.2015.0654
Q-bounds consistency for the spread constraint with variable mean, Constraints, pp.1-7, 2016. ,
