Abstract : Many fields are now snowed under with an avalanche of data, which raises considerable challenges for computer scientists. Meanwhile, robotics (among other fields) can often only use a few dozen data points because acquiring them involves a process that is expensive or time-consuming. How can an algorithm learn with only a few data points?
https://hal.inria.fr/hal-01374786
Contributeur : Jean-Baptiste Mouret
Soumis le : samedi 1 octobre 2016 - 13:17:31
Dernière modification le : jeudi 11 janvier 2018 - 06:27:29
Document(s) archivé(s) le : lundi 2 janvier 2017 - 12:55:02
