Stochastic Optimization with Variance Reduction for Infinite Datasets with Finite-Sum Structure
Stochastic optimization algorithms with variance reduction have proven successful for minimizing large finite sums of functions. However, in the context of empirical risk minimization, it is often helpful to augment the training set by considering random perturbations of input examples. In this case, the objective is no longer a finite sum, and the main candidate for optimization is the stochastic gradient descent method (SGD). In this paper, we introduce a variance reduction approach for this setting when the objective is strongly convex. After an initial linearly convergent phase, the algorithm achieves a $O(1/t)$ convergence rate in expectation like SGD, but with a constant factor that is typically much smaller, depending on the variance of gradient estimates due to perturbations on a single example.
