QuickeNing: A Generic Quasi-Newton Algorithm for Faster Gradient-Based Optimization
We propose an approach to accelerate gradient-based optimization algorithms by giving them the ability to exploit curvature information using quasi-Newton update rules. The proposed scheme, called QuickeNing, is generic and can be applied to a large class of first-order methods such as incremental and block-coordinate algorithms; it is also compatible with composite objectives, meaning that it has the ability to provide exactly sparse solutions when the objective involves a sparsity-inducing regularization. QuickeNing relies on limited-memory BFGS rules, making it appropriate for solving high-dimensional optimization problems; with no line-search, it is also simple to use and to implement. Besides, it enjoys a worst-case linear convergence rate for strongly convex problems. We present experimental results where QuickeNing gives significant improvements over competing methods for solving large-scale high-dimensional machine learning problems.
