Visual Contrast Sensitivity and Discrimination for 3D Meshes and their Applications - Archive ouverte HAL Access content directly
Journal Articles Computer Graphics Forum Year : 2016
In this paper, we first introduce an algorithm for estimating the visual contrast on a 3D mesh. We then perform a series of psychophysical experiments to study the effects of contrast sensitivity and contrast discrimination of the human visual system for the task of differentiating between two contrasts on a 3D mesh. The results of these experiments allow us to propose a perceptual model that is able to predict whether a change in local contrast on 3D mesh, induced by a local geometric distortion, is visible or not. Finally, we illustrate the utility of the proposed perceptual model in a number of applications: we compute the Just Noticeable Distortion (JND) profile for smooth-shaded 3D meshes and use the model to guide mesh processing algorithms.
pg2016.pdf (6.78 Mo) Télécharger le fichier
supplementary.pdf (11.93 Mo) Télécharger le fichier
Format : Figure, Image
Format : Other
Comment : Supplementary Material
Dates and versions
hal-01376275 , version 1 (09-11-2016)
Identifiers
Cite
Georges Nader, Kai Wang, Franck Hétroy-Wheeler, Florent Dupont. Visual Contrast Sensitivity and Discrimination for 3D Meshes and their Applications. Computer Graphics Forum, 2016, 35 (7), pp.497-506. ⟨10.1111/cgf.13046⟩. ⟨hal-01376275⟩
937 View
419 Download
Share
