Fault Detection, Isolation and Quantification from Gaussian Residuals with Application to Structural Damage Diagnosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annual Reviews in Control Année : 2016
Despite the general acknowledgment in the Fault Detection and Isolation (FDI) literature that FDI are typically accomplished in two steps, namely residual generation and residual evaluation, the second step is by far less studied than the first one. This paper investigates the residual evaluation method based on the local approach to change detection and on statistical tests. The local approach has the remarkable ability of transforming quite general residuals with unknown or non Gaussian probability distributions into a standard Gaussian framework, thanks to a central limit theorem. In this paper, the ability of the local approach for fault quan-tification will be exhibited, whereas previously it was only presented for fault detection and isolation. The numerical computation of statistical tests in the Gaussian framework will also be revisited to improve numerical efficiency. An example of vibration-based structural damage diagnosis will be presented to motivate the study and to illustrate the performance of the proposed method.
paper_final.pdf (570.13 Ko) Télécharger le fichier
hal-01376804 , version 1 (05-10-2016)
Michael Döhler, Laurent Mevel, Qinghua Zhang. Fault Detection, Isolation and Quantification from Gaussian Residuals with Application to Structural Damage Diagnosis. Annual Reviews in Control, 2016, 42, pp.244-256. ⟨10.1016/j.arcontrol.2016.08.002⟩. ⟨hal-01376804⟩
325 Consultations
442 Téléchargements
