Imperfect Forward Secrecy, Proceedings of the 22nd ACM SIGSAC Conference on Computer and Communications Security, CCS '15, pp.5-17, 2015. ,
DOI : 10.1145/2810103.2813707
URL : https://hal.archives-ouvertes.fr/hal-01184171
A Kilobit Special Number Field Sieve Factorization, Advances in Cryptology ? ASIACRYPT 2007, pp.1-12, 2007. ,
DOI : 10.1007/978-3-540-76900-2_1
Revealed: how US and UK spy agencies defeat internet privacy and security. The Guardian Online: https, 2013. ,
Algorithmes de logarithmes discrets dans les corps finis, 2013. ,
URL : https://hal.archives-ouvertes.fr/tel-00925228
Transitions: Recommendation for transitioning the use of cryptographic algorithms and key lengths National Institute of Standards and Technology, pp.800-131, 2011. ,
DOI : 10.6028/NIST.SP.800-131a
A Uniform Approach for the Fast Computation of Matrix-Type Pad?? Approximants, SIAM Journal on Matrix Analysis and Applications, vol.15, issue.3, pp.804-823, 1994. ,
DOI : 10.1137/S0895479892230031
How to Manipulate Curve Standards: A White Paper for the Black Hat http://bada55.cr.yp.to, Security Standardisation Research -Second International Conference, pp.109-139, 2015. ,
DOI : 10.1007/978-3-319-27152-1_6
A Systematic Analysis of the Juniper Dual EC Incident, Proceedings of the 2016 ACM SIGSAC Conference on Computer and Communications Security , CCS'16, 2016. ,
DOI : 10.1145/2976749.2978395
On the practical exploitability of Dual EC in TLS implementations, Proceedings of USENIX Security 2014, pp.319-354, 2014. ,
An Algorithm to Solve the Discrete Logarithm Problem with the Number Field Sieve, PKC 2006, pp.174-190, 2006. ,
DOI : 10.1007/11745853_12
Modifications to the Number Field Sieve, Journal of Cryptology, vol.6, issue.3, pp.169-180, 1993. ,
DOI : 10.1007/BF00198464
Solving Homogeneous Linear Equations Over GF(2) via Block Wiedemann Algorithm, Mathematics of Computation, vol.62, issue.205, pp.333-350, 1994. ,
DOI : 10.2307/2153413
The Eurocrypt '92 controversial issue: Trapdoor primes and moduli (panel), Lecture Notes in Comput. Sci, vol.658, issue.92, pp.194-199, 1993. ,
A Search Engine Backed by Internet-Wide Scanning, Proceedings of the 22nd ACM SIGSAC Conference on Computer and Communications Security, CCS '15, pp.542-553, 2015. ,
DOI : 10.1145/2810103.2813703
An L(1/3) Discrete Logarithm Algorithm for Low Degree Curves, Journal of Cryptology, vol.68, issue.226, pp.24-41, 2011. ,
DOI : 10.1007/s00145-010-9057-y
URL : https://hal.archives-ouvertes.fr/inria-00135324
Announce: OpenSSH 7.0 released, 2015. ,
Online order basis algorithm and its impact on the block Wiedemann algorithm, Proceedings of the 39th International Symposium on Symbolic and Algebraic Computation, ISSAC '14, pp.202-209, 2014. ,
DOI : 10.1145/2608628.2608647
URL : https://hal.archives-ouvertes.fr/lirmm-01232873
Designing and Detecting Trapdoors for Discrete Log Cryptosystems, Lecture Notes in Comput. Sci, vol.740, issue.92, pp.66-75, 1993. ,
DOI : 10.1007/3-540-48071-4_5
Discrete Logarithms in $GF ( P )$ Using the Number Field Sieve, SIAM Journal on Discrete Mathematics, vol.6, issue.1, pp.124-138, 1993. ,
DOI : 10.1137/0406010
Improvements to the general number field sieve for discrete logarithms in prime fields. A comparison with the gaussian integer method, Mathematics of Computation, vol.72, issue.242, pp.953-967, 2003. ,
DOI : 10.1090/S0025-5718-02-01482-5
URL : https://hal.archives-ouvertes.fr/hal-01102016
Nearly sparse linear algebra and application to discrete logarithms computations, Contemporary Developments in Finite Fields and Applications, pp.119-144, 2016. ,
DOI : 10.1142/9789814719261_0008
URL : https://hal.archives-ouvertes.fr/hal-01301496
2015-12 Out of Cycle Security Bulletin: ScreenOS: Multiple Security issues with ScreenOS, 2015. ,
Analysis of Coppersmith's block Wiedemann algorithm for the parallel solution of sparse linear systems, Math. Comp, vol.64, issue.210, pp.777-806, 1995. ,
Factorization of a 768-Bit RSA Modulus, Advances in Cryptology ? CRYPTO 2010, pp.333-350, 2010. ,
DOI : 10.1007/978-3-642-14623-7_18
URL : https://hal.archives-ouvertes.fr/inria-00444693
Discrete logarithms in GF(p) ? 768 bits. E-mail on the NMBRTHRY mailing list, 2016. ,
Revealed: The NSA's secret campaign to crack, undermine internet security. ProPublica Online: https://www.propublica.org/article/the-nsas-secret-campaign-to-crack-undermine-internet-encryption, 2013. ,
Constructing trapdoor primes for the proposed DSS, 1991. ,
The development of the number field sieve, Lecture Notes in Math, vol.1554, 1993. ,
DOI : 10.1007/BFb0091534
Additional Diffie-Hellman groups for use with IETF standards, 2010. ,
DOI : 10.17487/rfc5114
Generating efficient primes for discrete log cryptosystems, 2006. ,
On asymptotic complexity of computing discrete logarithms over GF(p), Discrete Mathematics and Applications, vol.13, issue.1, pp.27-50, 2003. ,
DOI : 10.1515/156939203321669546
Handbook of Applied Cryptography, 1997. ,
DOI : 10.1201/9781439821916
Polynomial selection for the number field sieve integer factorisation algorithm, 1999. ,
The Oakley key determination protocol. RFC 2412, 1998. ,
able to foil basic safeguards of privacy on Web. The New York Times, 2013. ,
Analysis and comparison of some integer factoring algorithms, Computational methods in number theory, pp.89-140, 1982. ,
Responses to NIST's proposal, Communications of the ACM, vol.35, issue.7, pp.41-54, 1992. ,
DOI : 10.1145/129902.129905
Discrete logarithms and local units Re: NIST announces set of Elliptic Curves. sci.crypt newsgroup posting dated, Philos. Trans. Roy. Soc. London Ser. A 47. M. Scott, vol.17, pp.345409-423, 1676. ,
Special prime numbers and discrete logs in finite prime fields, Mathematics of Computation, vol.71, issue.237, pp.363-377, 2002. ,
DOI : 10.1090/S0025-5718-00-01308-9
Response to Comments on the NIST Proposed Digital Signature Standard, CRYPTO'92, pp.76-88, 1993. ,
DOI : 10.1007/3-540-48071-4_6
CADO-NFS, An Implementation of the Number Field Sieve Algorithm, 2016. ,
