Adaptive Testing Using a General Diagnostic Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In online learning platforms such as MOOCs, computerized assessment needs to be optimized in order to prevent boredom and dropout of learners. Indeed, they should spend as little time as possible in tests and still receive valuable feedback. It is actually possible to reduce the number of questions for the same accuracy with computerized adaptive testing (CAT): asking the next question according to the past performance of the examinee. CAT algorithms are divided in two categories: summative CATs, that measure the level of examinees, and formative CATs, that provide feedback to the examinees at the end of the test by specifying which knowledge components need further work. In this paper, we formalize the problem of test-size reduction by predicting student performance, and propose a new hybrid CAT algorithm GenMA based on the general diagnostic model, that is both summative and formative. Using real datasets, we compare our model to popular CAT models and show that GenMA achieves better accuracy while using fewer questions than the existing models.
genma-vie.pdf (239.76 Ko) Télécharger le fichier
hal-01376944 , version 1 (15-12-2023)
Paternité
  • HAL Id : hal-01376944 , version 1
Jill-Jênn Vie, Fabrice Popineau, Yolaine Bourda, Eric Bruillard. Adaptive Testing Using a General Diagnostic Model. EC-TEL 2016 - 11th European Conference on Technology Enhanced Learning, Sep 2016, Lyon, France. ⟨hal-01376944⟩
284 Consultations
6 Téléchargements
