Schertz style class invariants for quartic CM fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
A class invariant is a CM value of a modular function that lies in a certain unram-ified class field. We show that Siegel modular functions over $Q$ for $Γ^0 (N) ⊆ Sp_4 (Z)$yield class invariants under some splitting conditions on N. Small class invariants speed up constructions in explicit class field theory and public-key cryptography. Our results generalise results of Schertz's from elliptic curves to abelian varieties and from classical modular functions to Siegel modular functions.
classinv.pdf (558.32 Ko) Télécharger le fichier
hal-01377376 , version 1 (10-10-2016)
hal-01377376 , version 2 (28-05-2021)
  • HAL Id : hal-01377376 , version 2
Andreas Enge, Marco Streng. Schertz style class invariants for quartic CM fields. 2016. ⟨hal-01377376v2⟩
427 Consultations
154 Téléchargements
