Identification of Regularities in CAD Part and Assembly Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The identification of regular patterns of congruent features in CAD models can enrich the object representation by a set of higher level information, which can be exploited for the reuse of the part model. In this paper, a method for the detection of regular patterns and symmetries of repeated subparts in B-Rep part and assembly models is proposed. The method is implemented as a plug-in of a commercial CAD system and detects linear, circular translational, rotational and reflectional patterns of congruent sub-parts of the model.
421082_1_En_33_Chapter.pdf (372.8 Ko) Télécharger le fichier
hal-01377460 , version 1 (07-10-2016)
Paternité
L. Chiang, F. Giannini, M. Monti. Identification of Regularities in CAD Part and Assembly Models. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.355-365, ⟨10.1007/978-3-319-33111-9_33⟩. ⟨hal-01377460⟩
55 Consultations
99 Téléchargements
