Abstract : Implementing design automation systems to automate repetitive and time consuming design tasks enables engineer-to-order manufacturers to perform custom engineering in minimum time. To maintain a design automation system, regular updating of design information and knowledge is necessary. Consequently, there is a need of principles and methods to support capturing and structuring associated knowledge, specially, design rationale. In this paper a method for capturing, structuring, and accessing to design rationale in order to support maintenance of design automation systems is presented. The method is tested through a design automation system that develops FEA (finite element analysis) models automatically. The results are evaluated in a case company which is a supplier to the automotive industry serving many brands and car models which each more or less requires a unique solution.
https://hal.inria.fr/hal-01377465 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, October 7, 2016 - 9:46:39 AM Last modification on : Thursday, March 5, 2020 - 4:41:59 PM Long-term archiving on: : Sunday, January 8, 2017 - 12:39:06 PM
Morteza Poorkiany, Joel Johansson, Fredrik Elgh. Capturing, Structuring, and Accessing Design Rationale Across Product Design and FEA. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.387-396, ⟨10.1007/978-3-319-33111-9_36⟩. ⟨hal-01377465⟩
