Information Quality in PLM: A Production Process Perspective - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent approaches for Product Lifecycle Management (PLM) aim for the efficient utilization of the available product information. A reason for this is that the amount of information is growing, due to the increasing complexity of products, and concurrent, collaborative processes along the lifecycle. Additional information flows are continuously explored by industry and academia – a recent example is the backflow of information from the usage phase. The large amount of information, that has to be handled by companies nowadays and even more in the future, makes it important to separate the “fitting” from the “unfitting” information. A way to distinguish both is to explore the quality of the information, in order to find those information that are “fit for purpose” (information quality). Since the amount of information is so large and the processes along the lifecycle are diverse in terms of their expectations about the information, the problem is similar to finding a needle in a hay stack.This paper is one of two papers aiming to address this problem by giving examples why information quality matters in PLM. It focuses on one particular lifecycle process, in this case production. An existing approach, describing information quality by 15 dimensions, is applied to the selected production process.
421082_1_En_75_Chapter.pdf (225.22 Ko) Télécharger le fichier
hal-01377512 , version 1 (07-10-2016)
Paternité
Thorsten Wuest, Stefan Wellsandt, Klaus-Dieter Thoben. Information Quality in PLM: A Production Process Perspective. 12th IFIP International Conference on Product Lifecycle Management (PLM), Oct 2015, Doha, Qatar. pp.826-834, ⟨10.1007/978-3-319-33111-9_75⟩. ⟨hal-01377512⟩
227 Consultations
213 Téléchargements
